05-12-2012, 12:00 PM | #1 |
Where does this plug go?
Yesterday I got up under the dasy of my '64,and I noticed that the connection where the steering column wiring hooks into the main harness was hanging down pretty low.
Do the two prongs on the harness stick in anything? |
05-12-2012, 12:10 PM | #2 |
Re: Where does this plug go?
Looks like a column plug to me but in the mid 60's truck there is only one not two. I wonder if someone over the years stuck a differnt harness in that truck.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
05-12-2012, 12:54 PM | #3 |
Are you are talking about the two plastic prongs sticking out of the bottom? If yes then they connect into a square hole that should be on the bottom of the column to hold it into place.
05-12-2012, 01:49 PM | #4 | |
Chevy Fleetside,it's possible but I think it's all original. I'm the 2nd owner,and I've had the truck for over 26 years. |
05-12-2012, 01:49 PM | #5 |
there is suppose to be a flat bracket that bolts to the steering column/brake pedal mount. the "christmas tree" retainer that is pinting down would snap into that... I will try and take a pic of mine this weekend and post it
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
05-12-2012, 01:51 PM | #6 |
Check The Champ, Demonstrator
You could have two plugs if the truck was optioned with an emergency flasher unit. The unit would have the adapters on the witing harness.
