Old 05-11-2012, 10:50 AM   #1
BCARDE
how to install cab molding on my 77
so i have a 77 and i just got the cab molding that goes under the back window and the two corners and i dont know how to install them
any advise?
BCARDE is offline   Reply With Quote
Old 05-11-2012, 05:18 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: how to install cab molding on my 77
the clips get riveted on and you push the moulding up and clip it in
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-11-2012, 07:03 PM   #3
BCARDE
I don't have any of the clips I just have the molding. Where can I get some clips to enstall and what do they look like?
Old 05-11-2012, 08:06 PM   #4
Square_78
Square_78's Avatar
I glued mine on with silicone adhesive
Square_78 is offline   Reply With Quote
Old 05-11-2012, 08:35 PM   #5
88Jimmy4x4
88Jimmy4x4's Avatar
try brothers, lmctruck or classicparts.com for the clips you need, they do sell them so attach it correctly
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 05-11-2012, 08:41 PM   #6
cory d
cory d's Avatar
my buddy and I are going to use double sided foam tape on his cab band so we dont have to drill into it, this stuff makes canopies a PITA to get off so i figured it would hold fine
cory d is offline   Reply With Quote
Old 05-12-2012, 07:24 AM   #7
Square_78
Square_78's Avatar
Use the 3M tape with the red backing. Its the best for trim pieces.
Old 05-12-2012, 09:21 AM   #8
old Rusty C10
alot of the body supply shops have the clips i got some extras from Albert Kemperle in NJ
there are also two holes that hold on the corners at least on the newer models
heres a place that has some all kinds for all cars FA1286 is the one i used pictured on this site
http://www.mrgusa.com/pdfs/34-39mclips.pdf
I would not use that 2 sided tape.. LMC sells rail caps and tailgate caps i have on my truck and both times that product failed and the items came loose and off..
Bob
I hate cancer!!
Old 05-12-2012, 05:01 PM   #9
Square_78
Square_78's Avatar
If you prep the surface properly, and do it at the right ambient temperature, it won't come off. Ive worked with 3M tape for years in the accessory business, and its ALL in the prep work. The tape in the picture wont work as its just mainly a foam tape to protect the trucks paint, but the tape with the red backing will work.
Old 05-12-2012, 05:18 PM   #10
cory d
cory d's Avatar
liek this stuff? http://www.walmart.com/ip/3M-6382-Do...Black/16795079
how do you prep the area? just with rubbing alcohol or something?
Old 05-12-2012, 07:27 PM   #11
Your41Plague12
Your41Plague12's Avatar
Wax & Grease Remover, and then an adhesion promoter. Let the remover dry completely and then use the promoter. Let the promoter dry for about 15-20 seconds, and then apply the tape. Trust me, it won't come off. I use it every day at work.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 05-12-2012, 07:41 PM   #12
cory d
cory d's Avatar
alright i'll try to find some of it locally
Old 05-12-2012, 07:42 PM   #13
dmartin1
dmartin1's Avatar
im wanting to do this with my 82 that came without it from factory.
so from what i take, the red backed 3m stuff can hold fairly well?
for the trim, its not just flat on the back side(side against cab) it has folded over rails along the edges where it pops or slides on the studs. so how exactly would you tape that?
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 05-13-2012, 04:06 PM   #14
Stepper86
Stepper86's Avatar
Exactly, I have the same question. I got a band+corners for my truck, but I donīt want to drill holes in the cab. But the way the band is shaped I think it will be difficult to "tejp" on.
Tom.______________________________________
The fleet:
2007 BMW 530xi M (daily driver)
1986 C-10 Stepside (project "my time")
1992 Corvette cab (summer time daily driver)
1969 Cadilac DeVille Cab ("it just need some paint")
Stepper86 is offline   Reply With Quote
Old 05-13-2012, 09:03 PM   #15
makman1297
makman1297's Avatar
I used the tape on mine a year ago, ended up taking the trim off, almost impossible witho out bending the trim, held great. For the gap your asking about i used foam tape that was sticky on one side,they have it at lowes and use if you installing toppers on beds, then the surface was flat, i put thin tape on the top and bottom and then a piece down the middle worked great. I plan on doing that again when i re-install the trim.
1981 Dodge D-150 (under construction)
2007 Chevy Suburban
2010 Dodge Charger R/T
1980 Kawasaki KZ 440
2004 Harley Sportster 1200
makman1297 is offline   Reply With Quote
77 chevy, cab band, cab corner, molding
