87 4x4 rear end id
im replacing the spider gears in my rear end so far this is all the info i have
1987 1/2 ton 4x4 305/350 glove box tag #GT4= 3:73 rr. axle gear ratio 10 bolts no tag anywhere i dont believe its positraction ( then i wouldnt need the spiders) & rather not take off the cover as yet, thought i would find that on the glove box sticker did search here for 10 bolt id, rear end id nothing came up. From the internet is its a 10 bolt corporate id like to order the spider gears but not totally sure if i have all info thanks Happy Mothers Day to all the ladies
1990 chevy 4x4 with a 1940 IHC body Last edited by peglegs; 05-13-2012 at 05:06 PM. |
Re: 87 4x4 rear end id
RPO G80 check out your glove box
not there what is that # for?
1990 chevy 4x4 with a 1940 IHC body |
RPO code are the three digit letter number combinations found on your glove box tag
so G80 is for limited slip.. your rearend is 28 spline 8.5" gm 10 bolt. pretty sure it started in 1988 and later versions are 30 spline, trucks and vans vin series ckv versions may not be though |
#5 | |
