Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 05-14-2012, 07:41 AM   #351
LakeAnna
LakeAnna's Avatar
Re: Crash's 72 K10
Your cab looks great! Are you making up all your own brake lines? I need to do this on mine...
Pontoon looks like a good spot to spend Sunday afternoon for sure.
Chris
72 RESTO
http://67-72chevytrucks.com/vboard/s...d.php?t=501870
LakeAnna is offline   Reply With Quote
Old 05-14-2012, 08:14 AM   #352
mcbassin
Still Learning
mcbassin's Avatar
Re: Crash's 72 K10
Good progress Mark, I did the same thing to my cab yesterday morning. I'm just trying to keep up with your now.....
Old 05-14-2012, 10:15 AM   #353
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks.. I did make my own brake lines.. but I am not sure if I will stay with them or buy some stainless ones.. just for the bling.. lol
I had a good time Sunday afternoon.. just relaxing and playing with the dog..
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 05-14-2012, 10:17 AM   #354
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
I am still way behind you.. still have some body work to do on the Cab.. Still need to tear the bed down... Most importantly I need to learn how to use that #(@&^%$ spray gun..
Mark
Crash's 69 4x4 SWB
Old 05-14-2012, 11:19 AM   #355
tsnow678
Re: Crash's 72 K10
What size of needle/jet are you using with the epoxy or high build? For high build I use a 2.3mm. For bases and clears I use a 1.3mm. This may have something to do with it and not so much on how your doing it.
Link to my 69 Camaro 6.0/T56 swap:
http://ls1tech.com/forums/conversion...69-camaro.html
tsnow678 is offline   Reply With Quote
Old 05-14-2012, 11:20 AM   #356
mcbassin
Still Learning
mcbassin's Avatar
Re: Crash's 72 K10
You are welcome to use my suction gun anytime
You might be better off shooting your primer with a suction gun or a non hvlp gravity feed? I don't know what would be better?
I do agree that sanding epoxy sucks.
Old 05-14-2012, 11:25 AM   #357
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
2.0 tip.. I really think it is a problem with how fast I was moving the gun. Near the end of the spraying I started going really slow with the gun and the results were much better.
Mark
Crash's 69 4x4 SWB
Old 05-14-2012, 11:26 AM   #358
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks Mike... I think what I have will work.. just need to spray with it more.. Thinking about sanding again and trying again at a slower pace..
Mark
Crash's 69 4x4 SWB
Old 05-14-2012, 01:31 PM   #359
mcbassin
Still Learning
mcbassin's Avatar
Re: Crash's 72 K10
You may be able to just shoot the high build over it if it's not too bad.
Just a thought.
Old 05-14-2012, 02:16 PM   #360
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Just a thought.
I thought about that.. What would happen if I did that? Would it still have the orange peel? If so, sanding high build has to be easier than sanding epoxy...
Mark
Crash's 69 4x4 SWB
Old 05-14-2012, 03:08 PM   #361
webfoot
Re: Crash's 72 K10
The tech sheet for your high build should recommend a tip. On mine it is 1.5-2.0. i used a 1.5 and it worked fine. SPI epoxy primer sands nice and is not near as pricey as PPG. I wouldn't worry much about how the high build looks after it is shot since you will be sanding most of it off anyway. 2.0 is a big tip so you may just need to adjust the material down some.
If you shoot epoxy, most epoxy primers have a 7-day or so "window" where the next layer will chemically bond to the primer so there is no need to scuff.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 05-15-2012, 11:51 PM   #362
sduckworth13
sduckworth13's Avatar
Re: Crash's 72 K10
Looks great, I'm doing the exact thing to my cab. I'm in the test fitting phase on the passenger side sheet metal. Glad to see you documented the entire rust repair. Its going to be alot of help to me.
Scott
sduckworth13 is offline   Reply With Quote
Old 05-19-2012, 10:40 PM   #363
RCbowtie69
RCbowtie69's Avatar
Re: Crash's 72 K10
Hey Crash,looking good on your build.Keep up the hard work & the progress going forward,love the pictures.Keep on truckin'
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 05-21-2012, 07:31 AM   #364
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
No work done of the Cab this week. I had the pleasure of replacing the batteries in our lake cart. They weigh a little over 100lbs a piece. Could have bought a Dakota Gauge set for what they cost.
http://www.dakotadigital.com/index.c...rod/prd776.htm
Saturday was spent on the beach with my wife and some great friends.
Sunday I worked on a cart for the bed.
More pics of the cab
Pic’s of the motor and transmission I need to sell.
Mark
Crash's 69 4x4 SWB
Old 05-21-2012, 12:42 PM   #365
fakerwade
fakerwade's Avatar
Re: Crash's 72 K10
Originally Posted by rcbowtie69 View Post
hey crash,looking good on your build.keep up the hard work & the progress going forward,love the pictures.keep on truckin'
x2 !!
Wade
JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!!
Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570
Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro
fakerwade is offline   Reply With Quote
Old 05-21-2012, 03:11 PM   #366
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks, I hope so.. I learned a great deal during the process.. Have a great day.
Thanks RCbowtie69…
Originally Posted by fakerwade View Post
x2 !!
Thanks fakerwade
Mark
Crash's 69 4x4 SWB
Old 05-28-2012, 10:25 PM   #367
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Great weekend at the lake. I only had a few hours to work on the truck. I disassembled the bed.
I have some rust to deal with on the floor, but the bed sides look to be on great shape.
I also modified the old seat that was in the truck for the shop, and built a stand for the TV in the shop.
Sunset on Lake Eufaula…
Next Friday I hope to sand blast the floor and shoot epoxy primer.. Hopefully cut out the rusted spots out.
Mark
Crash's 69 4x4 SWB
Old 05-29-2012, 08:19 PM   #368
RCbowtie69
RCbowtie69's Avatar
Re: Crash's 72 K10
Cool sunset crash,gald you had a good time with the famliy.Hope to see progress of bed soon,it's going to be one nice 4x4.Keep on Truckin'
Old 05-29-2012, 09:50 PM   #369
mcbassin
Still Learning
mcbassin's Avatar
Re: Crash's 72 K10
love the sunset pics, shop bench and oh yeah, pawn stars
Looks like you got the be tore down quick. Looking forward to more progress.
Old 06-06-2012, 10:01 PM   #370
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks.. Those type of sunsets is one of the reasons I enjoy being at the lake.. I hope the truck turns out nice.. but I wonder sometimes..
Mark
Crash's 69 4x4 SWB
Old 06-06-2012, 10:04 PM   #371
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks Mike.. just trying to get caught up with you...
Mark
Crash's 69 4x4 SWB
Old 06-06-2012, 10:04 PM   #372
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Another very slow weekend.. I am playing too much to get very much done…
I did start sand blasting the floor of the bed. Got the bottom of the bed completed and most of the top. I need more blasting media to finsh up.
Of course we have to have some rust.. it is only right..
Need to find an old bed to cut out the pieces I need, or maybe I can order something to fix the issues.
The bed has some drilled holes from different things being mounted in it. I think it may have had a propane tank mounted in it at one time.
Hopefully over the next few weeks I can get the floor of the bed repaired, cleaned up, and primered.
Starting to think about the doors.. I am considering buying repo doors but have heard nightmares about fitment issues. If any has an option on some doors being better than others please let me know.
Mark
Crash's 69 4x4 SWB
Old 06-07-2012, 07:16 PM   #373
Gardnervillain
Re: Crash's 72 K10
Wow! Great build! I wanted to know if you made your own fuel cell or purchased it? Also, it appears that it hangs a little lower than the tank you had before. I'm trying to decide which way to go as we have a rear tank from a Suburban we can use, but I love the look of your new one.
Gardnervillain is offline   Reply With Quote
Old 06-07-2012, 10:27 PM   #374
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Crash's 72 K10
Check out page 26 of the LMC online catalog, part #38-9628. Kind of pricey for a patch, but the only one I know of available other than buying the small bed floor patches (which don't have the rib ends) or a new floor. You can use the middle sections of another truck bed floor, but fing one that is not hammered bad or rusted can be a challenge because usually it won't be available to cut up. I had some pieces of a blazer bed floor from one I parted out and I made some with just flat sheetmetal for small spots.
hgs_notes is offline   Reply With Quote
Old 06-07-2012, 10:55 PM   #375
mcbassin
Still Learning
mcbassin's Avatar
Re: Crash's 72 K10
Looks like you have a plan to fix the bed. Your blaster works great. I need to get one of those as much as I hate blasting......
It was good to finally get to see your build in person. The pictures don't do justice to how good it really looks in person. You have a top notch build going. This truck will be super nice when done. Don't sweat the progress.
This time of year is lake time.....
