05-13-2012, 07:16 PM | #1 |
Help! Identify i6 250 I bought!
Hey guys, I have a 66 gmc that has an i6. The placard under the dash states its a 250. Here are the casting numbers on the engine in the truck
So I was at a swap meet today, guy selling a good engine out of a 66 Chevy pickup, same as mine, 3 on tree, stepside, 250 i6. I buy it, get home, notice differences Casting numbers off new engine Distributor setup on the original engine in my truck Rear plate empty Now, here's the distributor off the newly purchased engine. MUCH larger, and a different setup From what I can tell, the carb. Is different, and the valve cover is even different. I'm bummed, how could two i6 250s both supposedly from 66, one from gmc and one from Chevy be so different? What the hell do I have here? Are parts interchangeable? Thanks for any helps guys.. -Paul Posted via Mobile Device
1966 GMC stepdside shortbed- needs some love |
05-13-2012, 09:07 PM | #2 |
Re: Help! Identify i6 250 I bought!
The "original" engine appears to be a '69 by the Date Code on the Block. The 2nd Engine appears to be much newer.
There is a "Pad" to the left of the Distributor. Let us have the numbers on that pad. Bill
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
05-13-2012, 09:11 PM | #3 |
Thanks for the reply, I will get those numbers tomorrow!
05-13-2012, 09:18 PM | #4 |
In the meantime, I checked on the Casting Numbers from the Blocks.
The 3921968 is from 1964-1976, which covers the '69 Date on the Block. The 366855 is from 1966-1984. If all the parts on the newer engine are original, I would say that the engine is closer to 1984. I can see some kind of Date Code behind the dipstick on the newer engine, but it is not real clear to me. I see what could be an 8 or 9 (possibly '78 or '79). Bill
05-13-2012, 09:43 PM | #5 |
A pic I took earlier, of the new to me engine, by the dipstick
I will get pics tomorrow of the numbers by the dist. Posted via Mobile Device
05-13-2012, 09:52 PM | #6 |
The number is a 6. Most likely a 1976.
The numbers (and letters) on the Pad will tell us more. Bill
05-13-2012, 09:55 PM | #7 |
Thanks for the info Bill! I'll be sure to post the numbers and letters from the pad tomorrow night
05-14-2012, 08:01 AM | #8 |
Does anybody have a picture of the Pad by the distributor they has the casting numbers, I can't find them
05-14-2012, 08:19 AM | #9 |
You should pull the valve cover and see what the date is on the head ....Both casting numbers represent many years ,both are 250 casting numbers...From 75 up they had the intake cast into the head (integral head ) , but of course you can change heads easy enough...
05-14-2012, 08:45 AM | #10 |
I can actually see the Pad in one of the pictures (older engine with the shot of the Distributor and Fuel Pump). It's to the left of the Distributor and right in front of the Fuel Pump. The numbers won't be raised, they are stamped. Clean the Pad good. Use a magnifying glass if necessary.
BTW, these are called the Engine Code numbers. It will include the Date as well as the Engine Suffix Code (actually a letter or letters), the more important ones in this case. Bill
