Closed Thread
Old 05-10-2012, 09:07 PM   #5301
CRGRS 66
CRGRS 66's Avatar
Re: What did you do to your truck today?
Originally Posted by GMR-PERFORMANCE View Post
Take a look into the champion aluminum rad. Vs the cost of a re core. I know that I was less money to buy new.
Originally Posted by Rich 5150 69 View Post
x2
Thanks for the advice GMR and Rich, new rad arrived today, headed out for an extra long weekend in the morning will get it in next week.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline
Old 05-10-2012, 09:09 PM   #5302
CRGRS 66
CRGRS 66's Avatar
Originally Posted by cb1965 View Post
thanks. i have the stock shocks. havnt swaped the cpp lowering shocks. grille is from a gmc. If i remember correctly 60-66 gmc grilles are the same, in '66 they changed the letters from the roundish version to squared.
so it is a GMC, love the GMC's, very hard to come by, are you running stock shocks on the rear as well, any travel issues on the shocks?
Craigerrr
CRGRS 66 is offline
Old 05-10-2012, 09:14 PM   #5303
cb1965
cb1965's Avatar
its a '65 chevy. just love the gmc grille. stock shocks all around. no issues, but then again i dont haul anything
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline
Old 05-10-2012, 09:21 PM   #5304
CRGRS 66
CRGRS 66's Avatar
thanks, this fall when I tear down my front end I think I will do what you have done, not sure what to do with the back end, will wait and see how I feel about the rake after the front end is done. I think I like the rear stance, but suspect that the springs are sagging, fresh stock height springs may raise it up... So I don't think 4" drop springs will drop it 4" back there.
Craigerrr
CRGRS 66 is offline
Old 05-10-2012, 09:45 PM   #5305
Indian113
Indian113's Avatar
removed the tint on my back window,put on by PO! It looks like I'm going to have to make it my DD as the trans is out of my Dodge
Indian113 is offline
Old 05-11-2012, 08:07 AM   #5306
scottofksu
scottofksu's Avatar
They are connected and sound good. No drone while i was on the freeway. Sounds good at idle. At a constant speed the sound dies off and becomes just a low hum. got them from summit racing
I was thinking about doing that too! What length did you get?
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline
Old 05-11-2012, 06:36 PM   #5307
62 Barnfind
62 Barnfind's Avatar
Finished tearing apart by bed and removing the angle strips.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Old 05-12-2012, 12:14 AM   #5308
Ta2Don
Ta2Don's Avatar
Picked up the 350 that I've gotta get buttoned up and ready to go...
Ta2Don is offline
Old 05-12-2012, 12:16 AM   #5309
cb1965
cb1965's Avatar
these are 70".
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline
Old 05-12-2012, 01:06 AM   #5310
Chevy Fleetside
Chevy Fleetside's Avatar
I towed my truck to my shop 60 miles from my house with my Ford Ranger.. It must have looked funny. Monday I will paint the firewall and figure out how I am going to bring it back.
I also installed the Tailgate I for for FREEEEEEEE on to my 66.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 05-12-2012, 03:50 PM   #5311
bobbylast
bobbylast's Avatar
Originally Posted by doobiebro View Post
bobbylast how do the porta walls hold up on them tires. Ive seen them on VWs with the thinner tires. I heard they make noises at high speeds..is that true..
i havent driven it since i put em on. my dad says they can pull forward and catch wind at high speeds. i guess that would explain any noises.
i also have the 700 r 4 so i'll be finding out about that noise soon enough.
the portawalls seem to have a small buckle on 2 of my wheels and i cant seem to get it out. any one know any tricks?
If you used to be...then i guess you never were.
bobbylast is offline
Old 05-12-2012, 04:02 PM   #5312
bobbylast
bobbylast's Avatar
Originally Posted by steve'62 View Post
How do you put/apply portawalls?
my pop has an old manual tire machine. i broke down the tire on one side and the portawall slips around it behind the bead. after that you fill it with a little air and slowly work the portawall back into the seat. keep adding air a lil at a time to make sure you dont have some pushing out. i used a rubber mallet but it was black. after the first whack i put an old gym sock over it. (it makes black streaks). i'm still not 100 %. on 2 of the wheels i have a very small buckle in the white wall. i think it has something to do with the balance weights being in the front. i'm gonna pull em and re balance with the weights on the inside only.
Old 05-12-2012, 04:06 PM   #5313
bobbylast
bobbylast's Avatar
Originally Posted by shrunken66stroker View Post
Boxed in the drip rail.
i need to do this to my truck but ive been putting it off. this is something id like to learn about in detail. the guy i bought my truck from filled the drip rail with bondo. i hate to see whats under there.
Old 05-12-2012, 05:20 PM   #5314
markeb01
Senior Enthusiast
markeb01's Avatar
Replaced my gas pedal trim and my kid came over and swapped out my rear springs.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 05-13-2012, 12:28 PM   #5315
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Last couple of days....
Replaced value cover gaskets and underhood clean up
Checked all the fluids
Took a ton of "extra " wire out from under the dash from the PO
Rewired the trailer plug and controller
Rewired the stereo so it actually works
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline
Old 05-13-2012, 12:33 PM   #5316
wutnxt
Did i mention i can't wait to tow the 65 SB with the dually?..
the 1965 Chassis goes to the body shop to put the cab on this week and I amso looking forward to towing with power and more brakes.....
wutnxt is offline
Old 05-13-2012, 10:23 PM   #5317
dantimdad
dantimdad's Avatar
test fit the blasted and painted pulleys and brackets with the new, polished stainless button heads. They look fantastic.
I have to charge the battery and move the truck out of the way so I can finish taking everything apart and pull the engine... But, it started pouring down so that'll be next weekend.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 05-14-2012, 12:05 AM   #5318
doobiebro
doobiebro's Avatar
Turned over the engine (283) and fired it up for the 1st time....Was a bit worried since a friend overhauled it and I bought it as a package deal with a rebuilt 700R4 sitting in my storage building covered up for 6 years. 2 weeks prior I shot a squirt of motor oil in each cylinder to avoid snapping a ring. I removed the HEI dist and primed the oil pump for about 5 minutes while turning the harmonic balancer. Like my avator signature says...this truck has been a long going project with countless hrs and $$$ which I tackled this truck build my self. I have actually had dreams of driving my truck for the 1st time and worried my self to death on the out come of the trucks powerplant.... The moment of truth has come...She started right up and it sounded so beautiful!!!!!!! My wife and kids were so excited. I finally realized and told my wife why was I worried all this time on the engine for nothing???(((IT'S A CHEVY!!!!)))
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline
Old 05-14-2012, 12:11 AM   #5319
mud.man.rj
mud.man.rj's Avatar
Congrats on the fire up, happy for you, they sure do take time don't they, way longer than we think it will, gettin there though. Looks very clean.
mud.man.rj is offline
Old 05-14-2012, 12:37 AM   #5320
raic65
raic65's Avatar
Took the truck out for its maiden voyage after doing the brake swap.
raic65 is offline
Old 05-14-2012, 01:22 AM   #5321
_1966ChevyPU
_1966ChevyPU's Avatar
Cool Re: What did you do to your truck today?
I got the new tires in... but still waiting for the wheels. But I got the rest of the wood sanded down and ready for final prep for sealing. Mocked the rear tires up and cut the wood as needed to clear these monsters.
Bryan (Redneck)
'66 Chevy Longbed Fleetside
'12 Dodge Ram 3500
'08 BigDog Pitbull
'11 Cargomate Trailer (Toy Hauler)
_1966ChevyPU is offline
Old 05-14-2012, 08:34 AM   #5322
66 lwb cs
66 lwb cs's Avatar
Finally finished my cab mount conversion from the floating mounts to the solid mounts. Rolled her out dusted her off wiped her down and took off to fill the tank with some fresh gas after sitting all winter, and promptly ran out of gas. I guess the guage isn't that accurate after all.
66 C20 LWB CS 327/TH400 A/C
66 lwb cs is offline
Old 05-14-2012, 10:21 AM   #5323
doobiebro
doobiebro's Avatar
Thanks mud.man.rj...for sure...next time somebody ask me when Im gonna finish the truck....my response will be (I'll let you know when its done..)
Old 05-14-2012, 12:05 PM   #5324
el_bole
Doobiebro,
Truck looks great...look at that 283! I have a '61 ,myself.....and yes it takes longer than we think ha ha ha.....I am going with the same powerplant as you except with a 350 tranny....Im inspired by looking at your pickup to keep at putting mine on the road! Thanks,
el_bole
el_bole is offline
Old 05-14-2012, 12:07 PM   #5325
el_bole
Truck looks great bro! What wheels (and size)are you running on your truck? like the look...
el_bole
el_bole is offline
Closed Thread
