Old 05-14-2012, 11:31 PM   #4401
jasonhall
jasonhall's Avatar
Re: 67 cheby's Dropmember build thread
Awesome paint choices !!!!! Looks great
jasonhall is offline   Reply With Quote
Old 05-15-2012, 01:39 AM   #4402
c10derek
c10derek's Avatar
Location: Santa Barbara, California/Tuscaloosa, Alabama
Sweet!!! Nice to see a few different color choices on the forum
c10derek is offline   Reply With Quote
Old 05-15-2012, 09:24 AM   #4403
67cheby
67cheby
67cheby's Avatar
Thanks guys just trying to be different ! Here is a little progress from last night,fitting and trimming my core support to grill filler panel (trying to figure out how to attach them without visible screws), working on making a removeable cover for my radiator cap, and thinking of redoing the top of my fan shroud, it just looks a little plain !
67cheby is offline   Reply With Quote
Old 05-15-2012, 09:35 AM   #4404
raull
raull's Avatar
quote !!and thinking of redoing the top of my fan shroud, it just looks a little plain !
plain sometimes is good, helps keep the clean look also , just saying !!!
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 05-15-2012, 09:49 AM   #4405
67cheby
67cheby
67cheby's Avatar
so you think leave it flat, instead of a raised panel like the one i drew on it ?
Old 05-15-2012, 09:58 AM   #4406
raull
raull's Avatar
i think it will look nice as it will flow with the one in front of radiator by the hood latch , thats just me but lets see if anyone else agrees , come on boys lets hear it !!!!
raul
Old 05-15-2012, 10:08 AM   #4407
lolife99
67-72 parts collector,…
lolife99's Avatar
Mike,... I know you have alot of time in this,... but would it be easier to make the radiator side panel one piece with just 2 breaks in it.
Then the top piece could be broke to fit behind the hood latch.
Then you could bead roll it where ever you want
Maybe a large dimple dye where the radiator cap sits?
Just an idea.
Keith
Convert to disc brakes.
Old 05-15-2012, 10:11 AM   #4408
67cheby
67cheby
67cheby's Avatar
hmmmmmm....hadnt thought of doing it that way, i will look at that tonight ! on a side note how do you draw lines on a pic like that ?
Old 05-15-2012, 10:13 AM   #4409
lolife99
lolife99's Avatar
I use "paint" on my pc.
Keith
Old 05-15-2012, 10:14 AM   #4410
67cheby
67cheby
67cheby's Avatar
i have to have the pass side removable to fill the radiator
Old 05-15-2012, 10:17 AM   #4411
raull
raull's Avatar
i like that idea from keith , flows even better with the front panel !!!
raul
Old 05-15-2012, 10:22 AM   #4412
lolife99
lolife99's Avatar
The hardest part is the hidden fasteners.
The top of the original core support could be drilled for "door panel" type clips.
Or the grille filler could be drilled and held on with nice stainless "button head" screws.
Totally Stainless sell button head machine screws and sheetmetal screws.
Keith
Old 05-15-2012, 10:23 AM   #4413
Slick67
Sofa King Crazy!!
Slick67's Avatar
That would look cleaner than multiple cuts in it. Maybe a little more time for fitment but cleaner for sure. A couple of well placed bead rolls would get the "plain out of it" but still leave it not too "overdone". The radiator access panel that you will design for it will be a great touch........
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 05-15-2012, 10:29 AM   #4414
lolife99
lolife99's Avatar
I would bring the top piece all the way out to match the "peaks" of the core support and grille filler.
Keith
Old 05-15-2012, 10:32 AM   #4415
67cheby
67cheby
67cheby's Avatar
i think i am going to try that, thanks Keith ! now to figure out how to tie it all together ! I am thinking if i put a seam at each outside edge of the radiator i could make both of those panels removeabe to access the filler and to access the bolts to bolt in the radiator core support ?
Old 05-15-2012, 10:33 AM   #4416
67cheby
67cheby
67cheby's Avatar
LOL, yes exactly like Keith just posted ! but now that makes me want to make some sheet metal core to grill filler panels and weld them all together in one big piece so there wont be any seams !
Old 05-15-2012, 10:41 AM   #4417
raull
raull's Avatar
we just love to see you work !!!!
raul
Old 05-15-2012, 10:47 AM   #4418
67cheby
67cheby
67cheby's Avatar
LOL, i think you just like to see how many attempts it takes me to make something !
Old 05-15-2012, 11:14 AM   #4419
raull
raull's Avatar
practice makes perfection !!!!
raul
Old 05-15-2012, 12:33 PM   #4420
watahyahknow
watahyahknow's Avatar
there are those rubber stoppers that they use for hood alignment they usually screw into the bodywork at the corners , you could use those to hold the sheetmetal in place
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 05-15-2012, 12:52 PM   #4421
67cheby
67cheby
67cheby's Avatar
i have decided i will start tonight i am going to build the top cap like Keith drew (thanks for the idea) and also build new filler panels that i can step roll also and weld it all together to make one big upper cap/filler/hood latch !
Old 05-15-2012, 02:01 PM   #4422
raull
raull's Avatar
wohooo !!! lets roll
raul
Old 05-15-2012, 02:02 PM   #4423
watahyahknow
you might not want to trow the old stuff away maibe theres someone interested in the setup you have in the truck now and you get some of youre investment back on it
Old 05-15-2012, 02:04 PM   #4424
67cheby
67cheby
67cheby's Avatar
i always RECYCLE !! LOL
Old 05-15-2012, 02:20 PM   #4425
lolife99
lolife99's Avatar
Here's the "smoothest" filler panels I have seen,...
Keith
fiberglass inner fenders, pb hood hinges ", w/pb 4 link
