05-14-2012, 10:58 PM | #1 |
Wiper motor wiring
Hey guys I need a little helP
I need to know which wires control which speeds and which wire is the ground for the wiper motor if anyone can help with this it would be much appreciated Any info will help Thanks Brian Posted via Mobile Device |
05-14-2012, 11:29 PM | #2 |
Re: Wiper motor wiring
WIPER MOTOR AND TERMINAL FUNCTIONS
Re: wiper motor wiring (See photo below) Wiper switch plug: Black wire = low speed Dark blue (center) wire = wash Light blue wire = high speed The wiper switch wires are ground wires. If you remove the switch and simply jump them to ground, it will make each function work. **NOTE - for high speed, you have to ground BOTH light blue & black at the same time. Wiper motor plug: Yellow wires are hot. One goes to fuse box and the other goes to the other terminal on the wiper motor. (see photo) Dark blue wire connects directly to the dark blue wire on the switch plug. ( WIPER MOTOR PLUG): Yellow wire - jumps around to the other yellow wiper motor plug. (see photo) Light blue wire - connects directly to the light blue wire on the switch plug. ( WIPER MOTOR PLUG #2): single black wire - connects directly to the black wire on the switch plug.
1990 chevy 4x4 with a 1940 IHC body |
05-14-2012, 11:32 PM | #3 |
WINDSHIELD WIPERS......WIRING ETC.
http://67-72chevytrucks.com/vboard/s...d.php?t=390267 Concerns w/w pump <<<<<<<<<<>>>>>>>>>
05-15-2012, 12:13 AM | #4 |
Thanks a lot pep I really appreciate the info I will try that tomorrow night I am not using the built in washer pump so I am
Just trying to get the motor working and I am Using a Ron Francis wiring kit so some of this stuff I am having to figure out Thanks so much for the info guys Thanks Brian Posted via Mobile Device |
05-15-2012, 01:18 PM | #5 |
The Older Generation
Here's a thread I posted on wipers... http://67-72chevytrucks.com/vboard/s...d.php?t=413551 LockDoc
