Closed Thread
Old 05-13-2012, 03:50 PM   #4026
Pont406
Re: What did you do to your truck today!
4l80e is ready to go. Still waiting on driveshaft. Dont want to cut original shaft in case I'll go back to th400. Picked up 2 spare wheels for $20. More parts next week.
Pont406 is offline
Old 05-15-2012, 10:13 PM   #4027
Tmwoodall
Ordered my Bowtie overdrives 2004r today. Ouch/excited.
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline
Old 05-15-2012, 10:25 PM   #4028
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Level 3?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline
Old 05-15-2012, 10:46 PM   #4029
Tmwoodall
Originally Posted by 68GMCCustom View Post
Level 3?
2. Engine should be putting out right at/just under 400
Old 05-15-2012, 10:55 PM   #4030
RINC
RINC's Avatar
Yesterday one of my mechanics helped me out. He got all the running lights, marker an brake lights working.
Got the title in my name today. Tomorow I hope to get off work early nuff to run it thru emisions again so can get it tagged an registered
Chris
'69 C-20
'04 Jeep TJ
RINC is offline
Old 05-15-2012, 11:32 PM   #4031
Hotrob72
Hotrob72's Avatar
Changed my grill out to get rid of the black one and used a do it yourself bedliner kit.
I kinda hate bedliners although my bed was in pretty poor shape to start with.
1971 chevy c10 ECE 4.5/6 dropped
1970 suburban ECE 4/6 Dropped 45K original miles so far
1948 Ford Sedan
1941 Dodge COE
1932 ford roadster
the rest are normal drivers
Hotrob72 is offline
Old 05-15-2012, 11:46 PM   #4032
Lloyd C.
Originally Posted by Critter View Post
Well I didn't do anything TO my truck but I did do some stuff FOR it. I started enclosing my shop which is where I will (hopefully) finish the teardown and restoration. And I unpackaged my new welder which will (again hopefully) help with that as well.
Exact same welder I have. You'll love it.
Lloyd C. is offline
Old 05-16-2012, 09:10 PM   #4033
thewyseone
well yesterday i got my grant wood steering wheel on,today i took a break and cleaned my veloster.
thewyseone is offline
Old 05-17-2012, 10:23 AM   #4034
mtruckr
mtruckr's Avatar
Today, I talked to my truck nicely... VERY nicely. With a bit of sweat starting to run down my neck...
I was sitting in a line of traffic waiting to get through a stop sign...
the engine was warm, but after 3 or 4 minutes... when it was my turn to get with it or get out of the way... it DIED.
YIKES!
I mildly panicked and prob flooded it a wee bit. Shoulda just pulled the choke-
but after 30 seconds of self-cursing and 'waving' to the folks behind me (can't believe that NO ONE honked)... got it started and took my place in line.
Life goes on... sometimes there's just a bit of excitement thrown in to remind you who is in charge ! (I was probably just getting reminded to drive the darn thing more frequently)
Today I'm using it to haul around a sofa for someone, so maybe my attention will be rewarded...
mtruckr is offline
Old 05-17-2012, 10:30 AM   #4035
RexDodge
Installed the fuel filler door! Yes....
RexDodge is offline
Old 05-17-2012, 11:30 AM   #4036
lil hoodlum
lil hoodlum's Avatar
I've een on vacation this week so I have had plenty of time to take care of and fix quite a few things this week so far.
Changed oil and oil filter.
Checked transmission oil.
Replaced fuel filter.
Replaced starter with a rebuilt unit.
Cleaned up some electrical contacts in starting circuit.
Replaced ignition switch.
Repacked wheel bearings and greased up all suspension parts.
Drove out to the lake to do some fishing yesterday. No luck!
Going out again today!
Keith
lil hoodlum is offline
Old 05-17-2012, 09:27 PM   #4037
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
All but the ignition and one ground wire done on the Vintage Air. The cables were a b*^$h. But, that's because I do them about every six years. Hahahaha!
Dropped her off of the jacks to look at some wheel rub clearances. No apparent problems.
More cab work tomorrow. Short of adding fluids, and a trip to the A/C guy, I'm pretty much done under the hood....Maybe.
Waiting for bumper bolts. Gotta fill the differential. adjust the e-brake. Find the brake fluid leak up front. That's the worst part of this build so far.
Stainless lines. I'm having a real issue finding where the crap is coming from.
I'll have to pull the a/c controls out again because I'm still doing duct work and radio, etc.
Here are some pics from today:
http://tinyurl.com/7fdbgm2
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 05-17-2012, 09:44 PM   #4038
chevy72pu
chevy72pu's Avatar
Gave it a ride on my new to me lift.
How 'Bout them Dawgs!
'10 Traverse LTZ
03 Silverado Z71 ext cab
99 Yamaha Grizzly 600
72 C10 350/350 sportside bed.
68 C30 flatbed. 350 4-speed.
"I've got a good memory, it's just short!"
chevy72pu is offline
Old 05-20-2012, 09:22 AM   #4039
Rob H.
Rob H.'s Avatar
I loaded the truck up and went to the Spring Willys Reunion on Friday. I had enough Jeep parts on the truck to squat it a bit LOL! This was it's longest excursion from home, 200 mile round trip.
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline
Old 05-20-2012, 06:20 PM   #4040
Bennett68C10
Bennett68C10's Avatar
Tore my front suspension back apart and installed my porterbuilt tubular control arms and bags. Only got the driver side done, still need to do the passenger side.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline
Old 05-20-2012, 09:05 PM   #4041
Andy4639
Old member
Andy4639's Avatar
Cool Re: What did you do to your truck today!
I ordered these night before last!
http://67-72chevytrucks.com/vboard/s...d.php?t=525344
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 05-21-2012, 01:30 AM   #4042
ItsRandy
ItsRandy's Avatar
Let's see...I got my steering column (with all the new parts) back in. Got my new master cylinder bolted on but still have to install the proportioning valve and hook up the brake lines. Got some more of the wiring done (safety switch, brake light switch, cigarette lighter and steering column). The 100 amp alt I got from Jeg's has a short or something, shooting sparks out the back and only charging 13.1 volts so I took it off and sending it back tomorrow. I ordered my new Dakota digital VHX gauges from Summit last week...waiting for the UPS guy.
ItsRandy is offline
Old 05-21-2012, 02:10 PM   #4043
RINC
RINC's Avatar
Dang. All I did was bleed my brakes an passed the smog test.
Well atleast my driver is a legal driver now !
Chris
'69 C-20
'04 Jeep TJ
RINC is offline
Old 05-21-2012, 06:44 PM   #4044
Andy4639
Old member
Andy4639's Avatar
Got the LED front turn signals in today!
Now I have all my lights LED with a normal flasher.
Andy4639 is offline
Old 05-21-2012, 08:33 PM   #4045
magwakeenercew2jh
[QUOTE=Andy4639;5393023]Got the LED front turn signals in today!
Beautiful lights!!!
It's been busy around here. What a pain the ebrake was today. Cleaned up some of the Vintage Air wiring and temporarily "fitted" the steering wheel and glove box door.
Day off the truck tomorrow for honey-doos. I'll see what happens Wed.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 05-21-2012, 08:37 PM   #4046
Andy4639
Old member
Andy4639's Avatar
Inside the truck looks nice man! I like that wheel. Where did it come from?
Andy4639 is offline
Old 05-21-2012, 08:39 PM   #4047
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i wash it
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline
Old 05-21-2012, 09:53 PM   #4048
magwakeenercew2jh
I just looked at my Paypal stuff from way back and can't find the E-Slay transaction. The wheel was made in Italy for marine use. I used a Grant adapter and had to screw around to get the horn set up correctly. But real leather and wood. And nicely made. I think it was worth the effort.
I know the mfg. started with an "M". And the guys that were selling it were a marine outfitter from Tennessee or Kentucky, if I remember correctly. But, the older I get, the more my mind's like a colander.
Here's the wheel without all the wires around it.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 05-21-2012, 11:54 PM   #4049
Andy4639
Old member
Andy4639's Avatar
I like it looks good and well made. Italain to!
Andy4639 is offline
Old 05-22-2012, 12:42 AM   #4050
mud.man.rj
mud.man.rj's Avatar
Well got my inner/outer rockers/cab corners and new doors done and painted to match interior, seat back in again too. Also most of bodywork on front of truck, primed and painted semi black for now, getting closer to back on the street, just waiting for the new rims and tires still, a few more weeks for sure, lots of time for more bodywork.
mud.man.rj is offline
Closed Thread
