vin does not match the model code
my vin says it is a 71 but the model code i think that is says it is a 70 it hade a 71 gril on it and the mirror was bolted to the roof so what is it
The first model code it CE 20934 and thats it same with my other truck why does it not have all the other info that the vin decoder is saying in should have also is there a place that you can find out what the biuld sheet had on it nither of my trucks have had them in the truck Thanks
71 Chevy C/10 lwb 350 5 speed nv3500 3.73 rear end 2.5" Front Drop and 4" in the back Edelbrock perfomer rpm manifold Edelbrock 600 cfm carb Headmen headers Last edited by bad 71 chevy; 09-24-2003 at 07:23 PM. |
Inline 69
bad 71 chevy
What is the number off of the vin tag that is inside the drivers door jamb? Have fun
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
CE 241J621187
71 Chevy C/10 lwb 350 5 speed nv3500 3.73 rear end 2.5" Front Drop and 4" in the back Edelbrock perfomer rpm manifold Edelbrock 600 cfm carb Headmen headers |
Formerly yellow72custom
Looks like a '71 3/4 ton, V8 truck.........
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Model codes dont tell you the year... only what model the truck is.
CE 20934 Model codes break down different that vin codes. C = conventional cab E = eight cylinder 2 = 3/4 ton 09 = cab to axle dimension of 54 inches 34 = fleet side box the 09 would be a 59 if it was a GMC.... and I dont any real reason why they did it that way to still indicate a 54 inch cab to axle dimension.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
VIN CE241J621187
Model Year 1971 Chassis 2 Wheel Drive Body Style Pickup GVWR Range 5500-8100 Engine 8-Cylinder Assembly Plant Janesville, WI Sequential Number 621187
tHANKS GUYS
