Stylin
carb spacer 1" wood
Edlbrock 1" open wood spacer. ive got a 2 plane intake, did i screw up by ordering the open spacer instead of the divided, or did i? which one would be better on more torque/hp?
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
for torque and low end hp, do yourself a huge favor and get the divided spacer. i made the mistake of putting a 1" open spacer ona stock intake with a QJet. my low end power absolutely sucked. i took the spacer out, and it made a huge improvement.
I'm back with 2nd truck!
I disagree. I used a spacer on mine and it was open with my divided plane intake and actually helped in bottom end and torque. Sure a large tunnel ram won't help any on lower RPM and torque but this is such a small "tunnel ram" that it just helps the fuel and O2 blend better and creates more power.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
theres no real definitive answer about which style or height spacer will work best for a given motor....you really need to experiment w/ a few untill you find one that suits your needs.
Stylin
im gona run a performer 600cfm carb electric choke on a performer eps manifold
i was in a class a year ago where we used aluminum blocks to build things, we had milling machines and lathes and such. was hoping to be able to build a carb spacer since i havent found anyone locally who carries them. but had not luck. if its wood and you had a buddy in woodtech you could have him build you one.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
well im going to honest. i cant tell if mine runs better with or without it, but i need it on there to clear the area for thr EGR and EGR spacer. that is the only reason i put mine on.
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
