Closed Thread
Old 05-16-2012, 07:41 PM   #4201
kylep
kylep's Avatar
Re: How about some pics of 73-91 crew cabs
Originally Posted by stewartcrew View Post
New here, but here is mine...
A few weeks ago
and now..
17x10 wheels with 35's, 96 Tahoe front seats, and 350sbc for now(cummins future)
that is one good looking truck, think you can show some interior shots?
2001 Tahoe
1978 K30
kylep is offline
Old 05-16-2012, 10:27 PM   #4202
stewartcrew
Originally Posted by joe231 View Post
Nice truck!
Thank you!
stewartcrew is offline
Old 05-16-2012, 10:43 PM   #4203
stewartcrew
Originally Posted by Dieselwrencher View Post
X2 love the color and wheels man!
Thank you!
Originally Posted by v30crewcab View Post
Theres a 2wd crewcab that color running around here near me. its bone stock down to the white rims and hubcaps, except it has a cowl hood.
I would love to get my hands on that 2wd..Would be the best of both world's...
Thanks, this is the best I can do for interior shots right now. The center console is just sitting there as I plan on building a custom one that fits my needs. No carpet yet just some sound deading material..I had to lower the seats about 4 and a half inches..
Old 05-17-2012, 07:20 AM   #4204
rs72z
rs72z's Avatar
Nice truck. How did you lower the seats?
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline
Old 05-17-2012, 10:40 AM   #4205
stewartcrew
The driver's side is power so the mounting brackets where very tall so I just cut out desired amount and rewelded them. Only tricky part was I had one mounting point drop down because the floor as we all know is not flat. On the passenger side the seat has two sliding mechanisms one slides the whole seat up and out of the way for passenger entrance to the back and the other is the front back adjustment. I simply drilled the rivets out and took out the whole sliding mechanism for the passenger entrance to the back one and then cut the feet off the front back one and rewelded in there desired location..All in all it was very simply just a little time consuming and a lot of measurements..
Old 05-17-2012, 10:57 AM   #4206
The Liberace
Originally Posted by 1774btcrew View Post
Craig, PM me. Found 4 19.5 step van wheels here in town for you.
You should call me I found 4 80s BMX bikes!
The Liberace is offline
Old 05-17-2012, 02:01 PM   #4207
rambone86
hey guys , I'm stuck on what transfercase to swap into my 90 crew. I have a 90 cummins with a 47rh transmission. what have you guys used for this swap?
rambone86 is offline
Old 05-17-2012, 04:13 PM   #4208
v30crewcab
v30crewcab's Avatar
dodge 241, from a 89-93 will bolt to the trans, and have pass drop, as well as fixed yoke. thats what I ran in my crewcab when it was auto, before I went to the stickshift.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline
Old 05-17-2012, 05:12 PM   #4209
puppy
puppy's Avatar
Update: Lots of new parts
Most noticably the wheel and tires
Rear axle with 4.56 gears, detroit locker, rear disk brakes, braided hoses with AN fittings, relocated shock mounts, welded tubes
Front axle with 4.56 gears, dropped pitman arm, dropped draglink, rebuilt steering gear box, borgeson steering u-joint, sway bar disconnects
Made a rear bumper and threw a winch on the front
New exhaust, ORD steer box brace, tuned up and ready to roll
Engine is next!
'11 Z71
'88 V-30 Crew Cab
'87 V-10
'69 Camaro SS
'52 M38
'46 Rat Rod
Word of the wise should be sufficient!
puppy is offline
Old 05-17-2012, 07:34 PM   #4210
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Sweet! Very nice!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline
Old 05-18-2012, 07:09 PM   #4211
Leedogg
Went to Tampa Fl and picked up this bed and 2 bench seats. Going to run this bed til dad gets around to stretching the fenders on my original bed.
Ready to roll out to a car show next weekend-
1989 Chevy Crew Cab Dually - 454/400, Trans Am Hauler, Future bagged project.
96 Trans Am: 383/m6 - 11.98@115 on 315 M/T D/R's - 408rwhp 394 rwtq
05 VW Passat TDI - 38mpg @75mph
07 Bandit 1250S - Two wheeled fun!
Click here to see my FQuick Garage!
Leedogg is offline
Old 05-18-2012, 07:42 PM   #4212
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
You mean NP205? Dodge didn't go to the 241's until 94, and they are LH drop.
Ryan
1969 Chevy milk truck
Dieselwrencher is offline
Old 05-18-2012, 07:43 PM   #4213
Dieselwrencher
Leedog, your truck looks cool! Man those tires look like wide bicycle tires on those wheels!
Ryan
Old 05-18-2012, 10:03 PM   #4214
v30crewcab
v30crewcab's Avatar
nope, they had 241's in at least the 92-93's, if not all the way from 89, in the gas 4x4's. the cummins got the 205's. but since hes running an auto, its got the same 23 spline as the gas engines. the 94 up are drivers drop, and the 89-93 are pass drop. I still have mine sitting somewhere in the shop if you want a pic of it.
and some current pics of my crewcab!
71 longbed 5.3 4l80
Old 05-18-2012, 10:28 PM   #4215
Dieselwrencher
Ok, you're right, in the gassers they did. Your truck is looking good! I like that much better!
Ryan
Old 05-18-2012, 11:01 PM   #4216
v30crewcab
v30crewcab's Avatar
Thanks, its SLOWLY getting back together. I miss driving it real bad, but its getting alot of new stuff, and things fixed better so its going to be much better this time around.
71 longbed 5.3 4l80
Old 05-19-2012, 12:08 AM   #4217
GMC5.9cummins
[ first post but this is my truck 89 gmc with a 5.9 cummins
GMC5.9cummins is offline
Old 05-19-2012, 03:26 AM   #4218
joe231
joe231's Avatar
Engine is next!
Very nice!!
What lift and tire size?
CHEVY ONLY
joe231 is offline
Old 05-19-2012, 08:45 AM   #4219
Mattman2010
Mattman2010's Avatar
Engine is next!
Just when I thought I was 100% sure I was going to go back to a dually on my crew cab and you post pictures of this. That is a BA truck puppy. I'm with joe lift/tire specs please! Maybe a truck like that as a dually with thr same black and white theme would be cool too..
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline
Old 05-19-2012, 10:49 AM   #4220
Dieselwrencher
Very nice GMC!
Ryan
Old 05-19-2012, 11:50 AM   #4221
Leedogg
Thanks man! they are 265/35's "extra Load". you can run up to 150PSI in those tires, crazy. i run 50. The inners are E Load 16's. Should be able to haul anything i want. Got the stuff for a 6/8 drop, just waiting on Dad to get time at the shop to fool with my bed. Next year- it is gonna get air ride.
Leedogg is offline
Old 05-19-2012, 12:03 PM   #4222
Leedogg
Puppy- Truck looks awesom! Especially like the pic from the front. intimidating ride. The Bumpers with the fairleads are cool.
GMC5.9cummins- Truck is just full of bad ass. Why the light bar? wrecker?
Leedogg is offline
Old 05-20-2012, 12:23 AM   #4223
USSkoval
Nice! Grip Spurs on it? Have any pics of your traction bar setup?
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline
Old 05-20-2012, 01:01 AM   #4224
rambone86
damn! that's nice.
Old 05-20-2012, 12:19 PM   #4225
85sierraclassic
85sierraclassic's Avatar
looks to me like 6" inch lift and 36" goodyear military tires
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s
85sierraclassic is offline
Closed Thread
crew, crew cab, square body, squarebody, squarebody.net
