Old 05-12-2012, 09:00 PM   #26
mooseknuckles
mooseknuckles's Avatar
Re: Painiting My LSx
I like the painted intake.
mooseknuckles is offline   Reply With Quote
Old 05-12-2012, 09:12 PM   #27
jtp67-72
jtp67-72's Avatar
epoxy primer....satin nickel base clear with flattener....ls6 intake will be painted also....bling for accessories .......jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 05-15-2012, 06:08 PM   #28
osaltyone
osaltyone's Avatar
So the paint you guys are using... is it made for heat or does it not matter.
osaltyone is offline   Reply With Quote
Old 05-16-2012, 10:59 AM   #29
swb85
On a budget like Fred Sanford
swb85's Avatar
I used Duplicolor engine paint on mine, has held up great over the last 3 years. Chevy orange/red on the block & valvecovers and ceramic silver on the intake, waterpump & accessories.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 05-16-2012, 02:44 PM   #30
JNJchev77
Registered Cruiser
JNJchev77's Avatar
I would use some form of "High Heat" paint. Whether in a can or a little higher end paint (POR 15, Motor Coater, etc). As long as your cleaning process/prep is good, they will last.
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 05-16-2012, 06:55 PM   #31
osaltyone
osaltyone's Avatar
Thanks! was just wondering. I don't see than many options when I go look for high heat paint so I was not sure.
Old 05-16-2012, 07:03 PM   #32
JNJchev77
Registered Cruiser
JNJchev77's Avatar
This link will give you some options, very good stuff...
http://www.kbs-coatings.com/motor-coater.html
77' Chevy SB
5.3/4l60e combo
Old 05-16-2012, 11:02 PM   #33
themb2g
How well does the paint hold up on those F.A.S.T rails? I have the LSXRT with red anodized rails, and the red anodizing does not match a damn thing in my engine bay.
themb2g is offline   Reply With Quote
Old 05-17-2012, 09:29 AM   #34
swb85
swb85's Avatar
Those rails are actually from Speed Inc and are clear anodized aluminum, not painted. You can remove the red anodizing from your rails with oven cleaner, then polish the aluminum to a nice finish. Be careful with the oven cleaner as it can start eating into aluminum if left on too long.
Old 05-24-2012, 08:48 PM   #35
themb2g
Here is mine painted up but not completely finished
Old 05-24-2012, 11:27 PM   #36
gringoloco
A guy with a truck
gringoloco's Avatar
Nice accessory drive! What compressor does it use?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 05-25-2012, 03:26 AM   #37
themb2g
its the Vintage air accessory kit and comes with the compressor.
Old 05-25-2012, 07:53 PM   #38
Kainedogg
Kainedogg's Avatar
5.3 with LS6 intake and C5 FEAD
top is Hemi orange, pan is Chevy Orange and block is plain gloss black, all paints were rated for 500 degrees but I used a 1200 degree clear coat after.
Kainedogg is offline   Reply With Quote
Old 06-03-2012, 08:40 PM   #39
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Here's mine. Cleaned, cleaned, and cleaned. etching primer and shot it with fire red moater coater from KBS Coatings. Love the stuff!!
Name:  5.3 paint 5.jpg
Name:  5.3 paint 6.jpg
77' Chevy SB
5.3/4l60e combo
Old 06-28-2012, 02:52 PM   #40
jsbgump
Gone Fishing
jsbgump's Avatar
Mine
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 06-28-2012, 07:42 PM   #41
effects66
effects66's Avatar
Just painted...
Here is mine. Just finished painting. Now final assembly.
  • LQ9
  • L92 Heads
  • New stiffer Comp Springs
  • New Comp Cam XR281HR
  • GM Carb intake
  • Atomic EFI to look like old fashion carb
effects66 is offline   Reply With Quote
Old 06-29-2012, 10:33 PM   #42
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I think you'll be the 1st here with the atomic efi
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-29-2012, 11:10 PM   #43
effects66
effects66's Avatar
Yeah, I like a lot of things about it. I know there is mixed reviews on it, but it completes the look I am going for. My interpretation of a NASCAR, racing type of look. Well see how it comes out and how it the Atomic will perform.
Have you gotten to drive your truck yet? Was wondering how the new tranny is working for you.
Old 06-29-2012, 11:37 PM   #44
68GMCCustom
Not yet...had a dbw pedal problem. Got a new pedal today and all is well, codes seem to be clear. I hope to get some miles in tomorrow...if I'm lucky maybe even a pass or two! I'll try and remember the gopro!
Kurt -
Old 06-30-2012, 08:41 PM   #45
68Stepbed
68Stepbed's Avatar
effects66, what kind of valve covers are those? They look good!
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 09-21-2012, 11:47 PM   #46
effects66
effects66's Avatar
Sorry for the late response 68stepbed, the valve covers are from Katech. Great product. A little pricey but nice none the less.
