Old 04-03-2012, 07:19 PM   #1
blackbeaSSt
02 burb won't start
not the first time this has happened. gauges and lights etc. work just won't turn over. the first time it was low on gas and just adding a little gas fixed it.
well right now its showing just a tick under 1/4. im about to go try the gas thing again to see if that fixes it.
if so, are we looking at a fuel pump problem? i've seen things about a passkey this, and security feature that, under hood light being mercury and if parked on a slant will kill the battery, etc.
blackbeaSSt is offline   Reply With Quote
Old 04-03-2012, 08:10 PM   #2
clinebarger
Re: 02 burb won't start
Is the engine turning over with the starter, Your post is kinda confusing.
clinebarger is offline   Reply With Quote
Old 04-03-2012, 08:23 PM   #3
blackbeaSSt
sorry. maybe used the term "turn over" wrong!
BUT, 3 gallons of gas seemed to do the trick and it cranked right up. fuel pump problem?
Old 04-03-2012, 09:34 PM   #4
MadManAndrew
Sounds like a sending unit problem to me. You're showing more gas than you have?
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 04-03-2012, 09:52 PM   #5
oakstcustomz
oakstcustomz's Avatar
those body styles have alot of problems with the gauges for some reason. also i have done countless fuel pumps as well.
1965 Chevy C-20 slammed 292 L6 TH400
1967 Chevy C-20 on 91 suburban frame project(wife's)
1972 Chevy K-20 Mild 350/th350/np2o5 dd
1952 Ford Customline 2door kustom project
1967 Cadillac Superior Hearse (wife's)
1998 GMC Saffari (wife's dd)
oakstcustomz is offline   Reply With Quote
Old 04-04-2012, 08:10 AM   #6
blackbeaSSt
no it shows the correct amount of gas. just odd that a smidge under 1/4 and this happens. but i put in 3 more gallons and BAM, it works.
ugh. not what i wanted to hear. so it kinda sounds like a fuel pump huh? any way to test it?
Old 04-04-2012, 10:17 PM   #7
oakstcustomz
ugh. not what i wanted to hear. so it kinda sounds like a fuel pump huh? any way to test it?[/QUOTE]
for the fuel pump usually it wont start the first time. cycle key and it starts second time means fuel pump is going bad........gauges start showing false readings, had a 01 that ya put a full tank in it and still show empty!
Old 04-05-2012, 07:54 AM   #8
blackbeaSSt
hmm. well it wouldn't start any time. would just sit there and sound like it was going to crank and nothing. tried it numerous time to no avail. but then i put the gas in and it started right up.
Old 04-05-2012, 09:35 AM   #9
truckdude239
truckdude239's Avatar
if you install a new pump use a good pump like ac delco or dephi the aftermarket ones just dont last
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-17-2012, 09:01 PM   #10
Slow Build
Slow Build's Avatar
Sounds like these things have some type of fuel pump issues. I test drove a 2001 Tahoe yesterday that just shut off while I was driving it. Sales guy thought it was gas and put a few gallons in it and it still didn't start. Then they thought it was the alternator, not. They had to tow it back. They finally concluded that it was the fuel pump. I'm thinking about getting an older Tahoe now.
It's funny. I usually hang out in the 60-66 thread where we talk about restoring, modifying and identifying stuff. This forum seems to deal with alot more problem related content. Makes me wonder.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
