Re: 700r4 lockup question
my truck wants to stall out every time I shift it into gear. Could I have some of the same issues you guys are discussing here?
#2 | |
![]() Join Date: Oct 2011
Could also be unrelated to trans but worth checking into.... |
There are 2 wires that CAN come out of the connector at the trans. a blue and a red. Make sure someone didnt accidently wire in the blue wire instead of the red. The blue is for hooking up a switch if you want to manually lock the converter. The red goes through the brake switch and is energized when the brake switch is not acctuated.
I did say that the brake switch was working. After I hooked up the vacuum the system was working correctly except when cruising in third at 35mph it wanted to lock and unlock so a switch on the dash was my solution. Can anyone say for sure whether on not running with it locked Most of time if it hurt the TCC? I can now tell an obvious difference in all gears. I need a limited slip of some sort now!!
