Enough yoke?
Yesterday I dropped the engine into my 60 GMC Sub with a TH350 trans. As stated in the title, do I have enough yoke into the tranny? With a 3 3/4 inch shaft, 1 3/4 is into the trans with 2 inches out. I'll try pics too
Bob |
Re: Enough yoke?
I would want more in personnally. Are the engine mounts on the rear set of holes?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Re: Enough yoke?
I agree - that would make me nervous having it that far out. If the suspension drops completely going over a bad pothole, it might not be enough.
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck |
Never Ending Projects
Re: Enough yoke?
Every thing I have read and every shop I have dealt with regarding driveshafts has said you want 3/4"-1" exposed at ride height. I think you are asking for a lot of problems with the yoke that far out.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Re: Enough yoke?
I know that longer yokes are made...would that solve the problem? Engine is just about as far back as I want it BTW.
Bob |
Re: Enough yoke?
do it properly and retube your d/shaft. is the motor sitting in the proper place or is it just simpler where you have it
ron |
Re: Enough yoke?
