#26 |
Re: 66 Pickup original gas tank: pros and cons
Well I plan on putting my in cab tank in the bed and build a "box" for it. Kind of like a trunk in the front of the bed. I got my truck and the guy had put in a brand new tank in and I can't see spending @$300 to put it under my truck when I plan on slamming it to the ground. I think the trunk in the bed idea is the way I will go.
#27 | |
![]() Join Date: Oct 2006
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#28 |
you think you can just cut a Radiator hose and use it as a replacement to the old cracked one?.....
or will gas effect it?...............Hmmmmmm..food for thought
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
