Best power window kit???
I want one that the motor sits in the middle of the door.. or can operate without extending into the vent area of the door,must stay in the area of the window..
Re: Best power window kit???
I have a Nu-Relic, looks great I haven't insalled yet.
![]() Join Date: Aug 2004
Nu-Relic are made with OEM regulators and GM motors, they are supposed to be ( I dont have them) the best and nicest around. They are not cheap ( about $500) but if they work like newer truck PW, then they would be worth it.
I had some cheap universal power windows on my truck and took them out, they worked OK but just rather have the strong arm windows.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
![]() Join Date: Jan 2010
I've went back forth whether to do pw in our 66
I saw a kit that used the window crank as the switch. Was purdy trick Posted via Mobile Device |
Nomrlz, I have also seen that, I believe you can have the New-Relics do the same.
I want to see pics if anyone has them , one that mounts inline with the window is what I need ,has to mount at or behind where the pivot bolts for the window regulator ,I dont want the type that just turn the crank of the old regulator....
I was looking at a $100 universal that actually looked pretty good. I will be going with power windows, I'm sure. Not for $500, I would think I could retrofit something for cheaper.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
"Where were you in '62?"
![]() Join Date: Jul 2004
(( 1960-1966 Chevy/GMC Pickup Truck Restoration/Modification/Customization Ideas
http://67-72chevytrucks.com/vboard/showthread.php?t=402277 Power Windows: http://67-72chevytrucks.com/vboard/showthread.php?t=403946 63 C10 one piece windows http://67-72chevytrucks.com/vboard/s....php?p=3768123
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
Reviving this one... Trying to figure out how to use the setups out of my 92 chev. Anyone give this a shot yet?
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726 ![]() 66 fleet lwb- In process 64 k10 10inch lift 38.5's- In process 92k1500 400hp on 38.5-parts truck now 8( |
