Closed Thread
Old 05-22-2012, 07:01 AM   #4051
Clrussell
Clrussell's Avatar
Re: What did you do to your truck today!
In the past 2 weeks (that's how long it took me to find this thread again) I've drove my 71 more than ever in the past year.. (daily) broke an axle shaft in the front, ran out of gas, installed driver side battery tray and 2nd optima, bought a Dana 60 and rebuilt it with all the good parts, took the flat bed off and installed the original step side long bed, removed the body lift and installed new cab mounts, built 2 of my bead lock wheels and mounted one tire (which took about an hour of bolt tightening), washed the mud from te truck for a good 5 hours, and refilled with power steering fluid 3 times! I have some pictures, I'll post when I'm to my computer
61 apache
Clrussell is offline
Old 05-23-2012, 09:47 AM   #4052
Hotrob72
Hotrob72's Avatar
Still using the old beat up grill surround although I did re spray the black that was about wore off.......
1971 chevy c10 ECE 4.5/6 dropped
1970 suburban ECE 4/6 Dropped 45K original miles so far
1948 Ford Sedan
1941 Dodge COE
1932 ford roadster
the rest are normal drivers
Hotrob72 is offline
Old 05-23-2012, 09:53 AM   #4053
mtruckr
mtruckr's Avatar
...adjusted the carb settings to increase idle speed a bit. Then drove it to Mexican for dinner and got a free car wash (it rained).
mtruckr is offline
Old 05-23-2012, 01:13 PM   #4054
cattle_feeder
Ordered all new ball joints, tie rod ends, drag link ends, and axle seals. Now to find the parts to convert to disc brakes!
Improving Successes By Lowering Standards
1970 Chevy K-20
2001 Chevy K2500HD w/8100
1995 Buick Park Avenue
cattle_feeder is offline
Old 05-23-2012, 02:59 PM   #4055
shopking72
shopking72's Avatar
Drove it to a car show on Sunday. First show with my wheels on, felt good
1972 C10 LWB- 4.5 Front and 5 Rear Drop, 406/TH350
1966 Caprice
1968 Impala (Frame Off LSX Project)
2001 Tahoe LT
2013 Hyundai Elantra
2010 Kawasaki Z1000
shopking72 is offline
Old 05-23-2012, 03:21 PM   #4056
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
^^^^^^ Truck looks good..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 05-23-2012, 03:57 PM   #4057
shopking72
shopking72's Avatar
Thanks French!
1966 Caprice
2001 Tahoe LT
2010 Kawasaki Z1000
Old 05-23-2012, 05:57 PM   #4058
Stevo427
Restored my badges that havent been on the truck since the first one caught on fire. Nice to have the original badges back on my truck.
Stevo427 is offline
Old 05-23-2012, 05:58 PM   #4059
88fordf150
88fordf150's Avatar
Polished and painted my old grill.
Brad handshoe
88fordf150 is offline
Old 05-23-2012, 07:53 PM   #4060
MrSchaeferPants
MrSchaeferPants's Avatar
Little more painting.
68 GMC C2500 - 305 V6 - 4spd
MrSchaeferPants is offline
Old 05-23-2012, 10:23 PM   #4061
Andy4639
Old member
Andy4639's Avatar
Cool Re: What did you do to your truck today!
Nothing more prettier than a LWB truck done right. Absolutely Fabulous perfect looking stance. Very well done.
I like the wheels also!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 05-23-2012, 10:32 PM   #4062
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Working on cleaning this up today.
Figured I'd better take some pics and do some labeling before I pulled
all the fuses and started rubbing the markings off.
Glove box is in today, more (and, hopefully) final) adjustments on the Vintage Air
A/C and Defrost cables, some wiring under the dash over by the passenger's side.
Boy, my back's sore.....
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 05-24-2012, 12:26 AM   #4063
shopking72
shopking72's Avatar
Thanks a lot Andy!
1966 Caprice
2001 Tahoe LT
2010 Kawasaki Z1000
Old 05-24-2012, 12:35 AM   #4064
AustinScott
AustinScott's Avatar
I ordered my 5 lug conversion Axel kit from Mikes Bump & Grind Garage...
I cant wait to get them installed & loose the "mixed" rim look I've been running ever since I made my disk swap.
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi,
My 68-SWB Photo Build Thread
All my Google Albums
AustinScott is offline
Old 05-24-2012, 01:41 AM   #4065
ItsRandy
ItsRandy's Avatar
Finally finished my stainless steel brake lines. They didn't come out exactly how I would have liked, I had to re-bend a stainless "kit" to get them to fit. I changed a few things so it wasn't only problems with the "kit" but I would have been better of bending my own lines from straight sticks of stainless tubing.
ItsRandy is offline
Old 05-24-2012, 01:58 AM   #4066
PAWS 72
PAWS 72's Avatar
Been working for three days cleaning on paws truck. Got four shows coming up back to back.Done a few things I have been putting off for a while also.Happened to think about the spare underneath it. I dont think I would trust it anymore though.Original also
I have seen on hoods where the whole thing underneath was semigloss black,then between the braces was painted black,and then painted a solid color like mine what would look best on this one with it being that bright red.I thought paint between the braces satin black.what say you?
Have fun this weekend everyone and be careful on the road.
PAWS 72 is offline
Old 05-24-2012, 02:01 AM   #4067
PAWS 72
PAWS 72's Avatar
sharp truck.I don't like baggers ,I know yours isn't, but I like the stance.have a careful weekend
PAWS 72 is offline
Old 05-24-2012, 02:30 AM   #4068
Andy4639
Old member
Andy4639's Avatar
Thanks a lot Andy!
Your welcome! I like the LWB trucks.
Andy4639 is offline
Old 05-24-2012, 09:27 AM   #4069
Tmwoodall
Picked up this bad boy from the freight depo on Monday. With any luck, I will install it and the cab on Saturday.
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline
Old 05-24-2012, 01:54 PM   #4070
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I'm supposed to get my 4L85e today...and hope to install it this weekend too.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline
Old 05-24-2012, 05:25 PM   #4071
bgwss
bgwss's Avatar
Hey that picture is Delano not far my homestead.
1967 custom 351E V6 3/4 long bed
bgwss is offline
Old 05-24-2012, 05:28 PM   #4072
67cheby
67cheby
67cheby's Avatar
Looks great
67cheby is offline
Old 05-24-2012, 10:03 PM   #4073
68GMCCustom
here's my new trans! a new 4L85e from GMPP w/1350 yoke.
and already had my Hughes dip stick, Jiffy-tite -6 AN quick disconnect kit, 3/8" braided s.s. hose., ARP convertor bolts, fittings, and a transmission jack conversion for my jack.
Kurt -
Old 05-24-2012, 10:23 PM   #4074
69trk
69trk's Avatar
Are you planning on running a trans cooler? If so, where are you planning on mounting the cooler and how long are those jiffy tite braided hoses? That trans looks great... Is that a stock stall converter?
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline
Old 05-25-2012, 06:15 PM   #4075
68GMCCustom
Already have a cooler in front of, plus the one in; the radiator... but may upgrade to a plate style. Jiffy-tite are like 18" long I think. Convertor is rated 2200-2300 stall with a bbc...but thinking my little 6.0L makes enough it should stall the same or a hair higher.
I'm sure as time goes on, motor makes more power, and I start abusing it more...I'll put some aftermarket parts in. I'd like to know what is different between my 4L85e and the Supermatic 4L85e...then just duplicate it. I just couldn't stretch (+/-$500 more) any further when I bought this one.
Kurt -
Closed Thread
