Old 05-22-2012, 10:00 PM   #1
Matt_ks
Matt_ks's Avatar
Bed Bolt debockle
Im needing some help.... I've aquired parts and pieces to build a SWB for my 70 but i dont have any of the mounting bolts can anyone tell me what size and length i need to mount tje bed to my frame.. Any help woild be great
Matt_ks is offline   Reply With Quote
Old 05-23-2012, 03:50 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Bed Bolt debockle
ttt
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-23-2012, 04:34 PM   #3
SS Tim
SS Tim's Avatar
Might want to start with LMC to get the idea of what you want. Here is a page link, start here and page through. http://www.lmctruck.com/icatalog/cb/full.aspx?Page=38
Also two pictures one from LMC and another from an old GSPP catalog to clarify things.
I'm sure there are more suppliers. Where have you been looking?
SS Tim is offline   Reply With Quote
Old 05-24-2012, 11:54 PM   #4
oldspowered67C10
For a steel floor short fleet you need 3/8"x4" carriage bolts and you need 8 of them. Theres also some special top washers that have a offset hole.
oldspowered67C10 is offline   Reply With Quote
Old 05-25-2012, 10:38 AM   #5
gcburdic
Restoration Virgin!
gcburdic's Avatar
Alright Gents...it's time to leave this thread alone and the bickering to stop....Cliff you are a long time member, and we expect you to set an example by being helpful....if not, please keep your comments to yourself and off these threads.....
CONDUCT GUIDELINES & ACCEPTABLE USE POLICY
XIII. If you are a long time member, act like one. Lead by example and assist other newer members rather then attacking them. We look upon our veteran members to use this opportunity to teach the newer members the appropriate message board usage.
Geoff with a G
Old 05-25-2012, 01:01 PM   #6
DorianB
DorianB's Avatar
I didn't like the look of the offset washers, so when I was putting my bed together, I just got the biggest bolt that would fit through the hole on the braces that connect to the frame and just mounted them directly to the frame without the wood being on.
The edges and the bolts in most of the metal strips hold the bed down to the cross braces. It didn't look like it hurt anything in terms of strength.
In my opinion, it works best to have the seat out so you have room to flop your body around while standing on your head. -ashx2
DorianB is offline   Reply With Quote
Old 05-25-2012, 01:30 PM   #7
70STOVEBOLT
70STOVEBOLT's Avatar
What is the purpose of the washer with the offset hole?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-25-2012, 02:56 PM   #8
ls1nova71
ls1nova71's Avatar
Steel floors have square holes punched in them that hold the carriage bolt from turning but a wood floor the square hole wouldn't be enough to hold them so the off set washer has the square hole in it and the boards are counter sunk in the bolt hole area so that with the washer off set, when you tighten them it tries to spin the washer in the counter sunk area and it can't turn.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-25-2012, 03:12 PM   #9
Matt_ks
Matt_ks's Avatar
THANK YOU!
Old 05-25-2012, 03:28 PM   #10
SS Tim
SS Tim's Avatar
Matt,
Was my post #3 the information you were looking for? An earlier post of yours mentioned a bed bolt kit so that is what this was based on.
Old 05-26-2012, 12:09 PM   #11
Matt_ks
Matt_ks's Avatar
SSTim... The earlier mention of a bed bolt kit was because i have aquired parts and pieces from several different places, and i had no hardware to put it all together... That situation has been rendered complete not i was just wanting to know what size bolts i needed to mount the complete steel floored bad to the frame. As far as the washers go i dont believe they are used on a steel floor only on the wood floors to keep the bolts from turning....
Old 05-26-2012, 12:09 PM   #12
Matt_ks
Matt_ks's Avatar
Thank you for all the help!
