05-22-2012, 08:32 AM | #1 |
Power Steering hose
I tried a search on this, but didn't come up with what I needed. My power steering line doesn't fit. I'm running a truck accessory system with the saginaw pump. I changed the main pressure line fitting from the metric O-ring style to a 5/8"-18 inverted flare so my line would attach. The problem now, is the way the line is bent, it interferes with the block. I need to know if there is a specific year model hose that will fit. I really don't want to have to run AN lines and fittings. That crap gets expensive.
05-22-2012, 11:43 AM | #2 |
Truck and auto performance nut
Re: Power Steering hose
can you use this with the old fitting?
if not....Speedway seems to have a lot of poor mans solutions. speedwaymotors.com/search-power-steering-adapter
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
05-22-2012, 12:07 PM | #3 |
The fitting is taken care of. I took one out of an older pump with the correct threads and flares. The problem is the bent part of the hose itself interferes with the block. I don't mind buying a new hose, I just need to know if there's a particular hose that will fit.
I may get some pics a little bit later to show what the issue is. That is a pretty nifty little adapter fitting, though.
05-23-2012, 08:10 PM | #4 |
you could have just 'massaged' the line into shape with your hands. If it's metal...it will bend.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292 1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987 Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker |
05-24-2012, 07:31 AM | #5 |
I ended up doing this with a tubing bender, some wrenches, and a bench vise. It's not very pretty, so I may put something over the line to hide it.
