I am wondering which headlight bracket is for high/low the brackets are different does it make a difference? Been 2 years since I took them off, and I cannot remember which is which.
Also, where do I find replacement screws that hold the headlight brackets in place on the core. Thanks. 84 w/dual headlights Posted via Mobile Device |
Getting Old; Going Broke
Re: Reinstall headlamps, advice
Are the buckets not marked at all? They really should just go on one way though if memory serves. The retainers are a two piece item sold as a single unit. You can get them new from GM still, shows $1.50 list on them, part # is 15705372. You can also get them at O'Reilly, I show part MTM * 42119 and list is $3.99, surely that is for a set or something.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
Not sure if this helps, but "low beams" go on top; "high beams" go on the bottom.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
