Old 05-24-2012, 12:00 PM   #26
manimal
manimal's Avatar
Re: My New Fuel Tank Conversion
That's pretty nice set-up. I s'pose the Nova tank would work the same, right?
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 05-24-2012, 05:47 PM   #27
54belair
54belair's Avatar
Im glad you mentioned the slow fill issue------------ (I didnt want to bring it up)
If I see what I think I see (?), that could be your fill issue--------------In one of the pics, looking into the filler neck, it appears that your extension is slipped over the existing (on the tank) cap flange. I was wondering if the flange aprox. 6 inches down would cause backsplash when filling. Sounds like it might , if indeed the original neck flange is still there.
Ive talked to several guys at car shows who have done this type of tank install---and havent heard of filling issues (with the camaro tank and neck).
Anyway, its a thought-----------
54belair is offline   Reply With Quote
Old 05-30-2012, 01:47 PM   #28
utee05
I'm tempted to do a similar conversion myself. I just got a '72 GMC 1500 and would like to get the tank out of the cabin.
What size is the camaro tank? So did you end up just leave the original tank filler on the driver side cab? Also how close to the exhaust to the tank? I can't quite tell from the pics you provided? I have dual exhaust that may interfere with this type of conversion.
utee05 is offline   Reply With Quote
Old 05-30-2012, 04:50 PM   #29
bubbaj
Need to find you a gas station that you can Park down hill at
1970 c-10 lwb named "heavy metal therapy"
bubbaj is offline   Reply With Quote
Old 08-04-2012, 03:00 PM   #30
indianbullet
Location: North Cal and no Sac or Bay area is not NORTH
Tag for the genius speaker idea
Never argue with an idiot, they will bring you to their level and beat you with experience..
indianbullet is offline   Reply With Quote
Old 12-07-2012, 03:18 AM   #31
madeinalaska
Sub'd
madeinalaska is offline   Reply With Quote
Old 12-07-2012, 06:02 AM   #32
luvbowties
luvbowties's Avatar
Originally Posted by KellerMAC View Post
It is about 2" on both side, I used washers as shims so I could add them on both sides to get it level. The neck extension was out of necessity as we mounted the tank with the bed off and did not know the exact location of the bumper. But after seeing it all in place, I like the fact the tank is set back a ways from the bumper. So, I would recommend the neck extension.
I do have a question for the group - when I go to put gas in the tank, it is a tedious process. Some pumps are too strong and it runs a seconds and shuts off, and I have slow feed it and it sometimes drips on the pavement. I heard that if I add a long rubber tube on the vent spigot of the filler neck, then it will help with fuel back pressure. Any thoughts on this and any thoughts what I can do to reduce this problem?
Thanks in advance,
KellerMac
Hi Keller I just noticed something from your pics. I believe if you go back & cut off the cap-portion of the original filler neck, you will have much less blockage when pumping gas.
HTH,
sam
luvbowties is offline   Reply With Quote
Old 02-01-2014, 12:08 AM   #33
CBrown680
Wow! That is amazing, kudos to you. I am also planning on moving my tank out of the cab. I appreciate the documentation of your process as it will make my install go smoothly. Cool idea on the gas tank!
CBrown680 is offline   Reply With Quote
Old 02-01-2014, 06:23 AM   #34
Andy4639
Old member
Andy4639's Avatar
Question Re: My New Fuel Tank Conversion
Just wondering since I saw this last year on the Power Tour. Have you ever noticed gas coming out of the cap on hard acceleration? I was following a guy last June on the tour and everytime he nailed it he would loose a bunch of gas. It would just pour out of the tank. I finally cought up to him and told him. He was like what! His buddy stood behind the car and when he took off it left a nice puddle in the parking lot.
Just something to check on.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-01-2014, 01:27 PM   #35
BigRed76
BigRed76's Avatar
That's from having a bad gas cap. My '72 Cutlass has the same style fuel tank, with a good gas cap, and has never leaked a drop of gas out the back.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 02-01-2014, 02:27 PM   #36
mrolds88
Nice project MAC. Nice use of the stock tank too. I have one thought/ concern about your tank mounting. In the 4th pic that you originally posted (the one with the washer stack) you have the strap ending with an angle then going over to the bolt. I would think that after a time that the strap would straighten out an allow the tank to loosen. Two choices that might help would be to loop the end of the strap using a bolt with a tee end to bolt it in or to use a piece of angle iron to reinforce the end of the strap. Keep up the cool work!!
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 02-01-2014, 04:11 PM   #37
o6r1man
o6r1man's Avatar
Did you just use the camaro sending unit? And if so does the gauge read right?
1970 SWB "old flame"
1967 SWB c10 sold
1972 Elcamino 496
2012 Denali HD dmax
o6r1man is offline   Reply With Quote
Old 07-05-2018, 01:22 PM   #38
morepwr
Wow! You guys have some great ideas in action here! I love the rear fill under the license plates like the cars have.
morepwr is offline   Reply With Quote
Old 07-05-2018, 07:03 PM   #39
elorenzof
I love it. Subscribed.
elorenzof is offline   Reply With Quote
