05-27-2012, 06:38 PM | #1 |
Headlight Trouble
I took my truck to it's first cruise night last night and everything went great until i got into my truck after dinner and tried to turn on the head lights and had nothing. They were working earlier in the day and I even had lights working on the dash when the switch was on.
I've been looking all day for loose connection thinking that something may have jiggled loose during the drive, but so far no luck. Any suggestions at to what I should look into now, I'm not a wiring expert and really have never messed around to much with electrical systems so any advise would be helpful. |
05-27-2012, 06:59 PM | #2 |
Re: Headlight Trouble
Unplug the harness at the Radiator support. Sometimes they corrode and lose connection. Just need to clean them out. Either that or your high beam switch is bad. The easy check is to unplug it and use a jumper wire and see if the light come on. Maybe that one needs cleaning also.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
05-27-2012, 07:13 PM | #3 | |
05-27-2012, 09:09 PM | #4 |
No problem. and your welcome. That is usually where the problem is.
05-27-2012, 09:24 PM | #5 |
Never Ending Projects
Had the same thing happen. I was like WTF? Found the plug had vibrated out enough to unplug the lights. Doh! Easy fix.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
