#276 |
![]() ![]() Join Date: Jul 2002
Re: Project No-buck!
BTW, this is what I used when I hooked the serpentine setup to my 70 to make the alternator act right
ACDelco PN 8078 Adapter wire with resistor in it.
#277 |
Been driving the truck the last few days for work and around town afterwards. Should have to fill up tomorrow, so we'll see what the mileage is. I'm not expecting spectacular numbers with all the in town driving I've done.
I did get 3 compliments on the truck today, including one guy wanting to know how much I'd sell it for ![]() Tonight I looked for an oil leak. I can smell oil burning (like on exhaust) when I'm decelerating. I looked the engine over and it all looked dry except for just a drop or two at the back of the oil pan. I tightened up the pan bolts just a little more, but I don't really think that is the problem. Guess we'll see. Then I started cleaning up the wiring. The wiring in the "glovebox" area looked like a rats nest, so I got it taped up nicely and ready for some wiring covering tubing stuff. I also installed the glove box door. Finally, I took a look at my cruise control switch. Cruise control isn't working cause the switch isn't working. I'm not sure if the switch was bad before I pulled it out of the donor truck or if when I welded it to the original shaft if the heat from welding melted something inside. Anyone know of a switch that will fit our columns, but has the proper GM cruise control switch on it (on my 68 I used a dakota digital switch and used some relays to get it to operate properly with the LSx drive by wire stuff). |
#278 |
Checked my mileage after the first tank, 15.5mpg not too bad, but not as good as I'd like. Right now my speedo is off, so I'm thinking the engine isn't going into its lean cruise mode. 75mph shows 53 on the speedo, so its off quite a bit.
Today I worked on charging the A/C system. The A/C compressor started locking up, so I got a new one. Hope to get it installed here shortly. Also got some wiring stuff to hook up the cruise control with a custom switch setup using a toggle switch and two momentary switches. Also got some microswitches to disengage the system when I hit the brakes and/or clutch. |
#279 | |
Still plays with trucks
Sounds like it's time for some speedo calibration too.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
#280 | |
![]() One issue at a time, and the speedo being off (and its effects) are towards the bottom of the list. |
#281 |
I have A/C!!!! I still need to wire up the fan switch to the compressor clutch signal, but its working. Right now it blows out the defrosters or floor vent since I don't have dash vents yet. I'm going to add those eventually, but at least I should be able to stay pretty cool for now.
#282 |
I got the cruise control hooked up tonight. It is kind of working. When I'm going along about 60 and I engage the cruise control, it starts surgeing. I'm pretty sure its pretty much going close to full throttle then closing the throttle, then going back to full throttle. Doesn't really seem to be able to smoothly compensate. I'm wondering if its due to my throttle body spacer.....got some more digging to do.
#283 |
The other day while messing with my A/C my electric fan controler died. I was also popping 30A fuses, so I think something in there must have gotten fried. I hooked the fan directly to the battery through my DMM and measured 35A when it kicked on and then once up to speed it was down to 20A. Not sure if this is "normal" for one of the cherokee e-fans or not. So I got a new controller, relay and 40A fuse and it seems to be working fine. I have to get another relay (or diode) to make the fan kick on when the A/C kicks on. The new fan controler doesn't have an A/C input lead. Oh well, its been cool here lately so I haven't needed the A/C.
I started looking at installing the 3pt seatbelts out of the 90 donor truck. Looks like it should bolt in. Gotta get some bolts though. |
#284 |
Well, in life all good things must come to an end. Project No-Buck will be up for sale in the not too distant future. I picked up a 94 dodge 4x4 cummins pickup today to start my next project of putting a crew cab square body onto the dodge frame. The main motivation behind this is now that we have 2 kids, the whole family can't ride in either of the current pickups. So the dodge will take the place of the 69 until I really start in on the project.
Not sure what I'm going to list it for. Got a little odds and ends to clean up and get sorted out first (cover the wiring, get the cruise working). Then I'll take a look at my receipts, probably throw up with how much I spent on it, and then figure out a price. I've really enjoyed working on this truck, taking it from something most people would drop off at the salvage yard to a cool daily driver. Check out my new build thread on the square body forum:http://67-72chevytrucks.com/vboard/s...d.php?t=526664 |
#285 |
Same reason I sold my 78 K20, no point going forward with the project if it no longer suits your needs. Good luck with the sale and the new project.
#286 |
VA72C10
![]() Join Date: Mar 2008
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#287 |
it looks very nice and should be very easy to sell
#288 |
No buck is officially for sale
![]() I still have a few little things to do on it. I need to get a door handle and window crank for the pass. side and a new door handle for the drivers side. The button broke on the brand new one I got from LMC. Need to take it back there to get another one. I did get some new door panels made and a filler piece to make the A/C controls look better. Need to get some pictures of that. |
#289 |
You know, I hadn't seen this thread before I named my own "project no buck 72"! Good luck on the sale of your's and I hope mine turns out as nice when I'm done!
Rob 72 C/10 (under reconstruction)(destruction ? LOL) 48 Willys CJ2A 1952 Super "A" Farmall (Grandfather's) |
#290 |
Guess I'll update this thread. I put the truck up for sale after finishing up a few little things.
I made a little panel that holds the A/C controls in place: ![]() Painted the instrument cluster "carbon fiber" look. Kinda neat: ![]() Made some door panels (I have the armrest installed now too) ![]() ![]() That's about all the further I'm planning on taking the truck. It's been running good, but I'm needing to fund the crew cab build and get siding for my house.....can't do both ![]() |
#291 | |
![]() Join Date: Aug 2008
Posted via Mobile Device |
#292 |
I also swapped the vortec cam for a comp 4x4 torque grind and a set of their beehive springs. RN great for a 350. Roller rockers, rv morse ported TBI and Herman full length headers also helped. I ran the vortec fuel pump with an adjustable fuel regulator set to 15 psi.
#293 | |
#294 |
Sold the truck tonight. Kinda sad to see it go, but it frees up some cash. The new owner signed up on the board and actually works for the same company that I do, so I'll probably still see the truck around.
