Old 09-26-2003, 09:31 AM   #1
Fleetlover
Guess I'm not a real redneck
RIveted some patches on a couple of small holes in my floor last nite .( all I have time to do now ) Got some galvanized POR 15 ed the backs and stuck em down Got all done and realized A real redneck would have used old license plates Screwed up again .
Seriously does anyone know the source of the water\moisture that rots out the kick panel floor joint . Must be a design defect Seems that it might come from a bad seal around the windshield then behind the dash to the floor but not sure . Does'nt help to fix the result with out fixing the cause .
71 C10 Short Fleet coughing and sputtering
down the backroads
59 Apache short fleet
resto started now suspended
1884 victorian home Current
restoration project
1997 GMC Sierra Z71
1973 Harley FLH undressed
1949 male body somewhat abused
but still starts most mornings
Fleetlover is offline   Reply With Quote
Old 09-26-2003, 10:24 AM   #2
JimKshortstep4x4
Smile
I believe the rust at the floor kick panel joint is caused by water/debris accumulation in the rocker/front pillar area. The rockers are not vented enough to dry out the area and the rocker vents are so small any dirt getting into the rockers cannot get out.
Also, any windshield/antenna/cowl leaks will allow water to get in the corners without a way to be dried up.
When salt is added to the area, real rustout will occur!
On our AC cab that we are in the process of painting, I made another vent in the rocker and opened up the other drains. Also,
I am leaving the front plug out so that air can circulate better.
(The cab is from Arizona and is in great condition).
Here is a picture of the bottom that was painted recently.
Jim
Old 09-26-2003, 10:29 AM   #3
tom hand
CCRider
tom hand's Avatar
Hey,Hey ,hey....I just repaired my enclosed trailer where a tree limb had punctured the roof...used a license plate. Your from NY your not qualified to be a redneck anyway...lol
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 09-26-2003, 12:42 PM   #4
1971 Cheyenne
1971 Cheyenne's Avatar
Oh my god... a rust free cab! I'm drooling...
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 09-26-2003, 12:56 PM   #5
Fleetlover
JimK Looks loke a multitude of potential water problems . Have to check into additoinal drainage Not planning on driving mine in the winter so salt won't be a problem It's a N. Carolina truck so isn't too bad Would like to preserve whats left so when I do have time ( after the 59 ) there will be something left
Tom There's places in NYS where the inhabitants have necks as red as any south of the Mason Dixon Course without the southern drawl something is kinda lost .
down the backroads
restoration project
1997 GMC Sierra Z71
Old 09-26-2003, 01:10 PM   #6
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
I've seen proof of Rednecks around the world. Bullet holes in a street sign in France is define proof. 5 cars on blocks in the Phillipines is proof. One of the best Honky Tonks in Japan is proof. It's not a state, it's a state of mind.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 09-26-2003, 01:22 PM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
A real redneck uses duct tape.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 09-26-2003, 01:58 PM   #8
lukecp
Formerly yellow72custom
lukecp's Avatar
Or wood
I can't count how many old cars and trucks i have seen with a board resting over the holes in the floor pan.....lol.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 09-26-2003, 03:10 PM   #9
Randy70C-10
Randy70C-10's Avatar
You Arizona guys suck. lol.......I've never seen a cab in that condition before.
Randy70C-10 is offline   Reply With Quote
Old 09-26-2003, 03:16 PM   #10
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
i must be a true redneck the hole where someone had a shifter in floor i left uncovered it might come in handy if i ever start chewing/dipping lol
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 09-26-2003, 05:49 PM   #11
crazy longhorn
Fabricate till you "puke"
Originally posted by yellow72custom
Or wood
Stop signs work well for the bigger floor patches crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-26-2003, 10:44 PM   #12
Class of 69
Class of 69's Avatar
Or wood
When the forward end of the rear leaf spring came up under the seat of my 69 Camaro, I bolted a 4x4 to the floor pan to hold it down in place. Put the seat back in, and drove it for another year!!! And I don't have a Southern drawl.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 09-27-2003, 07:34 AM   #13
'68OrangeSunshine
'68OrangeSunshine's Avatar
I bought a K/5 rolling frame for parts last year. The rust corners in the floor were patched with flattened Pepsi cans and JB Weld. A surfboard decal gives the former owners'lifestyle away.
A rust patch in the passenger side cab floor of my '68 stepside, I figure, was caused by "CocaCola Syndrome." Every hot day I sip a cold pop then let the can roll around loose on the passenger side so it doesn't get underfoot on the driver's side and interfere with brake, clutch or gas pedal operation. A few drops dribble out and eat away at the floor pan. After 30 years this has an accumulative effect. Sometimes when the college kids are back in town, a riceball cuts me off and my big gulp spills: ergo massive corrosion.
Old 09-27-2003, 11:18 AM   #14
jcueckert13
jcueckert13's Avatar
all of you overlook the fact that a real redneck would have used a licence plate covered in duct tape and would have used bailing wire to secure it to the floor
1990 subaru legcy (daily driver)
1987 Toyota 4runner (weekend toy)
1968 C30 flatbed dually
1970 C10 longbed stepside (in pieces)
1976 Dodge Dart
1963 Dodge Dart
jcueckert13 is offline   Reply With Quote
Old 09-27-2003, 11:26 AM   #15
Hutch
Hutch's Avatar
You might have one of these:
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 09-27-2003, 11:49 AM   #16
dinnut
dinnut's Avatar
well, i guess theyre not rednecks, but it could be a redneck fishing boat
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 09-27-2003, 11:50 AM   #17
dinnut
dinnut's Avatar
2
70 longbed
496/th400/Ford 9"
Old 09-27-2003, 11:50 AM   #18
dinnut
dinnut's Avatar
and the worst part is. the government sank it.
70 longbed
496/th400/Ford 9"
Old 09-27-2003, 12:09 PM   #19
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
I sent a friend in West Virgina a couple of Neighborhood watch sign's to place on his 580 acre ranch . He gave one to a guy who was doing some work for him to cover a hole in his trailer's floor.
as they say." THAT'S THE HILLBILLY WAY "
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 09-27-2003, 05:06 PM   #20
weasel29gm
SLOW BUT SURE,BUT CLOSER
Gee I've used all that was listed,duct tape, road signs, pop cans bailin'wire and even a old Honda 305 muffler one time. When mine fell off. So that makes me a 1st class redneck!!! LOL!!!
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 09-27-2003, 06:28 PM   #21
jcueckert13
lets see so far my inner redneck has used bailing wire and jb weld to fix a radiator, held a carb together with bailing wire for a few months after the screws fell out, held the muffler to the car with bailing wire, fixed holes in floors, walls with licence plates as a matter of fact right now i nave a 3/4in. plywood stop sign repairing the floor under my water heater. i have used duct tape for a hole in the firewall, holding on body parts, and transporting furniture in the bed. if that isnt redneck enough i have even seen a cracked engine block on a tractor repaired with jb weld and bailing wire.
1976 Dodge Dart
1963 Dodge Dart
Old 09-27-2003, 07:14 PM   #22
Hooter
My other Love
Hooter's Avatar
my favorite way to fix a rusty floor, is to just stick a heavy piece of rubber conveor belt over it, works best in the box of the truck.
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 09-28-2003, 08:56 AM   #23
Green72GMC
Green72GMC's Avatar
Hey, I used cut up stop signs in my truck.
1972 GMC SWB, 305 powered
1980 diesel VW pickup, Needs a Heart Transplant
1997 Toyota Taco
The Second Amendment is in place incase they ignore the
others.
Green72GMC is offline   Reply With Quote
