Old 12-30-2011, 06:47 PM   #76
Apache63
1# Drobmember in Germany
Apache63's Avatar
Re: My new 1963 SWB 5.3 Vortec Pickup
today was my Garage day since a couple of month , install the new Steering Column and i was really nice to change it , very simple!!
so and here are the pic´s , in the 2nd pic is the reason why i changed it into a new column!
next step is to install the power steering , maybe tomorrow!!
Pat
Apache63 is offline   Reply With Quote
Old 12-30-2011, 10:58 PM   #77
Nobby
Nobby's Avatar
Looks Great! I love that wheel....
Nobby is offline   Reply With Quote
Old 12-31-2011, 12:36 AM   #78
allaboutchevelles
allaboutchevelles's Avatar
Looks really good!! So did that new columns wiring harness plug straight in the factory harness with no cuting of wires??
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 12-31-2011, 03:16 AM   #79
Fabian
Fabian's Avatar
Nice work Pat!
1964 Chevy C10 http://67-72chevytrucks.com/vboard/s...d.php?t=470509
1967 GMC "Sancho" built by Del http://67-72chevytrucks.com/vboard/s...d.php?t=516801
1961 Chevy Parkwood
1962 Chevy Impala Wagon
http://www.facebook.com/fabsspeed
Fabian is offline   Reply With Quote
Old 12-31-2011, 11:49 AM   #80
Dinos63
chevy only
Dinos63's Avatar
sweet nice work, still got those wheels ?
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 12-31-2011, 01:14 PM   #81
Apache63
Apache63's Avatar
Thanks Buddy ! ship it baby!!!!
the ugly one and the beast
in and nice
and the problem
the new pitman arm won´t fit because it is bend and the original one is straight , i used a 1979 Blazer powersteering!
i need help to get the right part!
help heeeelp heeeeelllllpppppp please!!!!!!!!!!
Pat
Old 12-31-2011, 04:04 PM   #82
duallyjams
duallyjams's Avatar
Was the Blazer a 2wd because the 4x4 will not work the sector shaft is different.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-01-2012, 01:42 AM   #83
Captainfab
60-66 Nut
I agree...
However in looking at the pic of the box closer, it is a 2wd steering box, as the sector shaft is threaded and has the nut on it. That pitman arm on the bottom of the pic is the correct one for a 2wd steering box, and should work just fine on your truck Pat. If there is a clearance problem, the box may not be positioned correctly.
Old 01-01-2012, 06:34 PM   #84
Apache63
Apache63's Avatar
Thanks Guy´s , i´ll check the clearance!!!
Pat
Old 01-02-2012, 04:51 PM   #85
Fabian
Fabian's Avatar
!!!! Done?
1961 Chevy Parkwood
Old 03-20-2012, 01:57 PM   #86
Apache63
Apache63's Avatar
I used a Ididit Steering Column and i bought a adapter from American Autowire Systems with part #37618 and it works perfekt "plug and play"!!
Pat
Old 05-28-2012, 05:58 PM   #87
Apache63
Apache63's Avatar
i had trouble with water pump , i figured out that she was leaking but i didn´t found the leak at the first sight !
so i had another water pump in my garage (nearly new without the upper water neck)!
a buddy of mine welds an adapter in and now i´ve an sender for the Water temperature , next will be install a adapter for the oil pressure !
Pat
Old 06-15-2012, 10:15 AM   #88
Apache63
Apache63's Avatar
One shoot from the "Bottrop Kustom Kulture" last weekend!
Pat
Old 06-15-2012, 10:18 AM   #89
jasonhall
jasonhall's Avatar
Awesome!!!
jasonhall is offline   Reply With Quote
Old 06-24-2012, 01:19 PM   #90
Apache63
Apache63's Avatar
Sitcker from the Bottrop Kustom Kulture !
Pat
