Old 05-29-2012, 01:18 AM   #1
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Lost My 65
Okay, I figured out what I'm going to do to tide me over as I fix body panels and rust repair.
I want to fix only the critical areas that I don't want to allow to get worse.
The hood has some surface rust and the fenders need some help.
Here is what the truck looked like in 2004:
Here's a truck from these forums where the guy mixed a little blue in with primer gray:
So it got me thinking;
I could add some flat black to blue to match the color,
and then add flat white to lighten the shade to match.
I have some SPI Epoxy Primer that I'll put in direct contact with metal as I clean an area up.
Then I'll paint that repair area with my color match mix.
Then, down the road when I can afford to give it a good paint job,
I can just strip the whole truck and only strip the repair areas down to the SPI Epoxy.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 05-30-2012, 12:35 AM   #2
Captainfab
60-66 Nut
Re: Lost My 65
Just a FYI, there are certain primers that are tintable. They can be mixed to what ever shade of blue you want. I know PPG makes them, but they are $$$. Seems to me that SPI makes a blue in the Hot Rod Flatz paint they sell. Of course this all is dependant on the budget.
