Re: 1963 rpm install help,,
What is a RPM?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
rpm guage
Senior Car Nut
![]() Join Date: Jan 2008
AKA tachometer or "tach"
mexlokote, basically you're going to need a wire from a key-switch-on power source, a ground wire and a signal wire. if you want the tach to light up when you turn the lights on you'll also need a wire from the light switch. what tach are you using? do you have points/coil or HEI?
Larry |
But Found Her 25yrs Later!
![]() Join Date: Jun 2006
LMFAO!!!!!!! Doesn't anyone know how to read a book anymore??? What's a book right?
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
I know what RPM means....just never heard of a part called RPM to install.
#7 | |
