Old 05-30-2012, 03:24 PM   #1
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
1989 Suburban "V Rig" Gets Cummins Power
This is a customer's of mine's truck. It used to be a City of LA Power and Water truck and is rust free. It has a 6" lift on 35's with custom diamond plate here and there. The NP205 in it let go and he had been wanting to upgrade this thing for a while. He mows lawns and is a full time fire fighter. He had a 02 F-350 7.3 DRW super duty, but sold it to get away from the Ia DOT regulations for commercial use. He sold the 350 and TH400 from this burb, and purchased a 92 Dodge for a donor. we're using the engine, transfer case, and axles from the dodge for this. We're using a 47RH and we're rebuilding it as well. Here's some pics.
Engine before pressure washing
Engine in burb for mock up
Right now I'm building the engine cross member and engine mounts. I will be using 1st gen dodge style, and using 2 per side. Let the fun begin!
Ryan
1969 Chevy milk truck
Old 05-30-2012, 03:27 PM   #2
Dieselwrencher
Re: 1988 Suburban "V Rig" Gets Cummins Power
The start of an engine mount
I have the intercooler out being widened and the new aluminum radiator needs to have bigger inlet and outlet installed in the tanks.
Ryan
Old 05-30-2012, 09:13 PM   #3
Mattman2010
Mattman2010's Avatar
Working fast on it man! Take pictures of the mounts. I want to see how you plan on doing thr two per side. That's what you told me to do so I'd like to see how you accomplishment that!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 05-30-2012, 09:55 PM   #4
v30crewcab
v30crewcab's Avatar
Have you tried using the chevy mounts? thats whats in mine, been working great for 6 years. I've busted the square older dodge ones in my scout with a 4bt!
what happened to the 205?
looks like fun.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is online now   Reply With Quote
Old 05-30-2012, 10:48 PM   #5
Cherub
Cherub's Avatar
man im digging that big yellow suburban.... i wish my garge would hold mine.
Cherub is offline   Reply With Quote
Old 05-30-2012, 11:36 PM   #6
Dieselwrencher
looks like fun.
I doubt you'd break them if you get the poly ones. They're a lot stronger. The 205 input broke. It'll be fun when it's running again.
Ryan
Old 05-30-2012, 11:38 PM   #7
Dieselwrencher
I'll take pics for you. They are going to look something like this when done.
Ryan
Old 05-31-2012, 10:50 AM   #8
Mattman2010
Those mounts look pretty stout. Looking forward to your take on how you do it!
Build Thread
Build Thread
Thread
Old 05-31-2012, 03:37 PM   #9
Dieselwrencher
Those mounts are what I build for ford super dutys.
Here is some cross member planning. I will build this out of 1/4" steel, and it will be a boxed in unit.
Ryan
Old 05-31-2012, 07:34 PM   #10
Mattman2010
Looks like a good plan. Do you just have the motor setting on jack stands in there? It also looks like your going to have to do something with the water inlet? It looks like the frame is in the way.
Build Thread
Build Thread
Thread
Old 05-31-2012, 07:58 PM   #11
Dieselwrencher
Yes, the engine is sitting on stands, and the trans is sitting on the trans cross member. I haven't decided yet what i'm going to do for the water inlet, but yeah, it's not going to work right now.
Ryan
Old 05-31-2012, 09:36 PM   #12
v30crewcab
v30crewcab's Avatar
must have it pretty low. I'm using that same water inlet on mine.
71 longbed 5.3 4l80
Old 05-31-2012, 09:57 PM   #13
Dieselwrencher
Yep, it's real low. Trying to keep u-joint angles and center of gravity lower. I might raise the engine up a little bit so I don't have to modify that inlet, but this truck has a weird firewall to floor flange. I had to cut 1.5" out of it and weld it back together to get the engine that far back. I've never seen one like it. I wish I would have taken pics before I cut it.
Ryan
Old 06-12-2012, 05:55 PM   #14
Dieselwrencher
I brought the engine up a little bit, and have been working on the engine cross member. It shouldn't be long now.
This is what your work area will start to look like when you do one of these.
The cross member will bolt in and will be fully boxed. It is made from 1/4" steel. The brackets in the frame are 1/4" as well. I doubt it will go any where.
Ryan
Old 06-12-2012, 07:00 PM   #15
spudz
spudz's Avatar
sweet!!! I want a cummins powered chevy truck.. Seems you are ALWAYS swapping a cummins in something lol. I am gonna load up my 87 crew cab, a dodge for parts and drop off at your place... You should have it done in about 3 days seeing how fast you move lol.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 06-12-2012, 07:00 PM   #16
Mattman2010
Looking good. How exactly are you bolting the cross member to the frame? It looks like you have ] shapes on the end of the cross member to go around the frame [?
PS: when are you bringing a trailer and picking up me and my truck and all its parts?
Build Thread
Build Thread
Thread
Old 06-12-2012, 11:52 PM   #17
Dieselwrencher
3 weeks, yeah, IDK about that. I tell you what, these chevys make me love the 86 up fords. The fords you don't have to build a cross member like this.
Ryan
Old 06-12-2012, 11:56 PM   #18
Dieselwrencher
Yes, I made [ pieces that the RH side slips in the frame, and on the LH side it sits on top of the frame rail flanges. These will be bolted to the frame, and then the cross member will bolt to these.
On the PS, probably when you are on 2 feet and not back on a bucket behind things with 4 legs.
Ryan
Old 06-13-2012, 08:10 AM   #19
Mattman2010
That makes sense. I guess you moved the engine up just enough for the water inlet to be used? I just went back and looked at pictures you sent me of my motor and noticed that its water inlet goes down. so I could probably set mine down in the frame a little lower?
... I dont even know how to respond to this.
Build Thread
Build Thread
Thread
Old 06-13-2012, 03:30 PM   #20
Dieselwrencher
Yes you can, or you can change the inlet as well.
And
Ryan
Old 06-13-2012, 08:24 PM   #21
Mattman2010
And
No I dont want to have to buy anything else for that motor! Seems like everything I am getting with it has to be changed for a dodge part!!!!
Build Thread
Build Thread
Thread
Old 06-20-2012, 03:11 PM   #22
Dieselwrencher
I've been working on this project, and making head way. I got the LH mount tacked together, and put the radiator support back on to make sure everthing still cleared. I removed the engine, and am now drilling holes in the cross member, and welding it up. I decided to go with a single mount on each side instead of two. I recently spoke with 2 old customers that I did conversions in 93-97 K30's, and they both wished their mounts weren't so rigid. They like that it's nearly solid, but don't like the entire truck shaking at idle. So, I decided to use one per side since this truck will more than likely see over 450hp, and the owner will daily drive it.
I ran out of wire, so I couldn't finish welding it up. Next thing is to get the axles out of the donor truck and get them ready for this.
Ryan
Old 06-22-2012, 07:45 AM   #23
greguw
Looks great buddy , you may want to add a little more support to the front steering box area while the engine is out . There is a a lot of stress on those thin C channel frames .
The push pull steering dose not work very well with GM's 4x4 design ... 2wd works fine .
Looks like a nice conversion , I have the 1990 cummins build over in the Blazer / Sub section .
greguw is offline   Reply With Quote
Old 06-24-2012, 02:08 PM   #24
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Nice project! Are you using the first gen intercooler, and what exactly are they widening on it?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 06-25-2012, 01:49 AM   #25
Dieselwrencher
Thanks Greg. I was thinking the same thing on that area. I need to at least add a brace in there. I followed your burb build and it turned out awesome!
Ryan
