Old 06-01-2012, 12:25 AM   #1
awitate
Easiest power sterring conversion
Hi everybody! I've got a 63 1/2 ton that someone already put a 350 in to. Everything else is looks stock. My question is what kit out there could I install with minimal headaches. Keep in mind I'd rather save time than money. THANKS IN ADVANCE!
awitate is offline   Reply With Quote
Old 06-01-2012, 12:42 AM   #2
jocko
jocko's Avatar
Re: Easiest power sterring conversion
i highly recommend the Captain...
http://67-72chevytrucks.com/vboard/s...d.php?t=332923
Old 06-01-2012, 12:54 AM   #3
losthope
losthope's Avatar
x2
Cant go wrong with the captain support a member!
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 06-01-2012, 01:06 AM   #4
Captainfab
60-66 Nut
Thanks for the recommend guys
I've been needing an avatar for a long time.........
Originally Posted by losthope View Post
x2
Old 06-01-2012, 01:10 AM   #5
Captainfab
60-66 Nut
Not knowing what the PO has done to your truck regarding the engine installation, I can not guarantee no headaches, but converting to power steering really isn't complicated. The one part that could be an issue, is what water pump was used on the 350 will determine what pump, brackets and pulleys you will need. Pics of what you have will be a help.
Old 06-01-2012, 07:40 PM   #6
awitate
Hey captainfab, here are some pics. The engine is a 350 from a 71 impala and I can see 2 available spots for belts I'm guessing for the power steering and air conditioning.
Old 06-01-2012, 09:17 PM   #7
rbar
rbar's Avatar
Looks like long pump, should be easy 70's conversion. FYI, there's a factory setup for sale in the boise craigslist. I prefer the conversion, but a purist could use it, $150.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 06-01-2012, 11:41 PM   #8
brap999
brap999's Avatar
I installed the power steering kit from CPP. It only took a couple hours, and supplied everything you need.
The only recomendation i have is to not use the power steering adapter CPP supplies, and instead use Captainfabs so you don't have to trim away the bumper bracket and make other modifications. Captainfab's is a better design.
1963 Chevrolet C10 Stepside
1972 Pontiac GTO
1998 Dodge Viper GTS
1999 Jeep Cherokee XJ
2018 Chevy Camaro ZL1-1LE
It's never too early to beef up my obituary
brap999 is offline   Reply With Quote
Old 06-02-2012, 01:17 AM   #9
Captainfab
60-66 Nut
Yep, you have a long water pump. There are 2 differences in them as far as power steering pumps are concerned. One pump (I don't remember the year range, but I believe it is late 70's) has a threaded boss there on the drivers side where the PS pump mounts. The other has just a smooth bore hole. The lower bracket for that pump will have a nut welded to the back side of it. Another thing to be aware of is the different fitting styles for the hose connections. The pumps and steering boxes prior to 1980 have an SAE inverted flare fitting. After 1980 they used a metric fitting with an O-ring. The conversion goes a little easier if you have both the pump and steering box with the same fittings. The pressure fitting in the back of the pumps can be changed, but you will have to have the one you need to switch to, so you may as well switch the whole pump.....unless there is something wrong with it.
Old 06-02-2012, 01:17 AM   #10
Captainfab
60-66 Nut
Old 06-02-2012, 01:04 PM   #11
MARTYZ
MARTYZ's Avatar
I just did mine using Captains frame bracket and I don't think you can find an easier or cheaper cost way to do it. Great results.
If you have all the pieces and couple hours of ambition you will be done.
Good luck
MARTYZ is offline   Reply With Quote
Old 06-02-2012, 01:33 PM   #12
rbar
rbar's Avatar
I used a frame bracket from cpp, but I would try Captain Morgan's, I mean Captain Fab's. Mine lined up a little crooked and I ended up installing a joint in the column to resolve it.
1965 Chevy swb 383
Old 06-02-2012, 01:37 PM   #13
awitate
Re: Easiest power steering conversion
There is no doubt that captain fab's adapter plate is the way to go. What about the rest of the parts? Is CPP's kit the way to go or get everything seperatley online, maybe some other kits out there? I was also thinking this might be a good time to start getting some chrome parts. Any thoughts?
Old 06-03-2012, 12:34 AM   #14
chopper john
chopper john's Avatar
captain fab. !!!!!!! Great price and service. but best of all, great product.
chopper john is offline   Reply With Quote
Old 06-03-2012, 01:29 AM   #15
Captainfab
60-66 Nut
The pump, steering box, hoses and belt can be found new/rebuilt at your local auto parts store, or you can get used ones at a wrecking yard, craigslist, etc. The pump brackets and pulleys you can find at either a local wrecking yard, craigslist, or ebay. The brackets and pulleys can also be purchased new from various sources. The classifieds here on the forum is also a good source for these parts.
