06-02-2012, 02:19 PM | #1 |
ok..so what could it be
I replaced a bad fuse for the turn signal. The new worked for a little then when out again. So i replaced the fuse again using a 20amp fuse. After ten minutes driving it when out again. What could the problem possibly be?.
Posted via Mobile Device |
06-02-2012, 03:04 PM | #2 |
Re: ok..so what could it be
short circuit because of a broken wire maybe?
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
06-02-2012, 05:40 PM | #3 |
A bad fuse would be one that didn't do it's job and allowed your truck to burn up. Let's call it a good fuse for doing what it was supposed to do.
Does the fuse blow when you signal left or right? Or is it intermittent regardless of signal operation? |
06-02-2012, 05:45 PM | #4 |
Sounds like a short somewhere
06-02-2012, 08:19 PM | #5 |
I'm not quite sure. It started yesterday...Replaced the fuse with 15 amp...%minutes later it blew again...Figured a 20 amp would maybe work. It blew. So I replace again this afternoon and it's lasted all day. I was on the road for 200 miles today....This is so weird. I check for frayed wire and found nothing. The only thing I could think of was I may have touched the contacts before install the first two yesterday. It was dark and I was working with a less than adequate flash light.
06-02-2012, 08:21 PM | #6 |
sabaka...I would say intermittent; however, I wasn't paying attention. I figured the replacement fuse was the answer to the problem.
