Gas Gauge issues
Just bought a 1986 K10 SWB 4x4 with a 4" lift and 33's 2 days ago. trying to fix some of the issues i have. my gas gauge is everything but accurate. sometimes it will read dead empty the you hit the gauge with your fingers and it will slowly go up to a certin point and drop a little. it just slowly moves where ever it wants and has a mind of its own. anyone know what could be causing this issue? a bad ground? a bad gauge? i dont know where to go from here. any advice will be helpful. Thanks, Brandon.
Re: Gas Gauge issues
If you are getting some reaction from tapping the gauge it could be some corrosion or bad contacts behind the gauge, that's where I would start.
John 82 Chevy Silverado 350ci/TH350
Moderator
![]() Join Date: Oct 2008
Corrosion on or loose calibration resistor.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
I would check the contacts as previously said, the gauge contacts are spring terminals and the gauge just pulls out once the bezel and lens are removed.
I would try reseating the gauge a few times them put some contact lube on the contacts and try that. |
| Bookmarks |
