Old 05-29-2012, 11:52 PM   #1
CigarMan
Gas tanks?
Can someone share with me the options of bed tanks for efi motors? I'd like to keep fill neck in bed. Do I really have to spend $700 on a Boyd tank to accomplish this?
CigarMan is offline   Reply With Quote
Old 05-30-2012, 09:28 AM   #2
MAK191
Re: Gas tanks?
I just picked up a 89 Jeep wrangler 2.5 liter 15 gallon tank from Advance auto parts. I got the idea from mrhino's build http://67-72chevytrucks.com/vboard/s...=427417&page=2
I have not installed it yet but here is what I think
Pros:
I like that the bumper almost completely hides it.
Cheap paid about $100 for a brand new one.
Appears to accept common GM sending unit/pumps with slight modification
Internally baffled
Cons:
Filler tube is only 1 inch
Only 15 gallons
hope that helps
Mike
MAK191 is offline   Reply With Quote
Old 05-30-2012, 02:03 PM   #3
ls1nova71
ls1nova71's Avatar
Re: Gas tanks?
What year is your truck? Wanting to" keep the fill neck in the bed" makes it sound newer than a 72. If its a 73-87 you can just get an 87 tank since they are already set up for EFI, just change the TBI pump for a higher pressure pump and you're done.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-30-2012, 02:17 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Gas tanks?
1 sheet aluminum, 2 AN bungs, tank foam, ruler. Doesn't get a whole lot more bare bones than that. It has a sending unit as well, although its not hooked up. Holds about 15gallons, doesn't slosh, and its sumped to run an external FI pump without issue.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-30-2012, 07:50 PM   #5
72gmcshorty
72gmcshorty's Avatar
Re: Gas tanks?
Pros:
Internally baffled
Cons:
Only 15 gallons
hope that helps
Mike
I also did this. I put in a fuel pump for a FI full size blazer and it fits perfect...
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 05-30-2012, 08:19 PM   #6
not2oldchevy
Re: Gas tanks?
What year blazer and which engine are you using? Looking for a pump that will run a 5.3 Thanks Bill
not2oldchevy is offline   Reply With Quote
Old 05-30-2012, 11:57 PM   #7
CigarMan
Re: Gas tanks?
Truck is 72 lwb , I would like to use as large of tank as I can get. I would like to fill tank from the bed, do not want to put side door or behind plate fill( hoping to install hitch there)
Old 05-31-2012, 10:24 PM   #8
72gmcshorty
Re: Gas tanks?
The pump was from a full size blazer. 1990 i think. It has to be fuel injected and a 15 gallon tank. Not the 21 gallon tank... look it up on rockauto.com
1992 Gmc 2wd
Old 05-31-2012, 10:45 PM   #9
shrunken66stroker
shrunken66stroker's Avatar
Re: Gas tanks?
CPP has a 22 gallon tank with a fill neck going through the bed floor(if that's what you mean) for $500. Not cheap but the fab work is great and it comes with the sender, neck, cap and fittings.
shrunken66stroker is offline   Reply With Quote
Old 06-01-2012, 10:50 PM   #10
chevydrivor73
Re: Gas tanks?
Here is what I plan on doing for mine.
http://www.73-87.com/7387garage/chas...ellinstall.htm
chevydrivor73 is offline   Reply With Quote
Old 06-02-2012, 11:58 AM   #11
Kainedogg
Kainedogg's Avatar
Re: Gas tanks?
I am doing an ls swap as well, and am considering the '87 fuel tank. Apart from the fuelpump and pickup, what is the difference between that my '84 tank? Can I simply stick the efi crap in my existing tank?
Kainedogg is offline   Reply With Quote
Old 06-02-2012, 02:01 PM   #12
ls1nova71
ls1nova71's Avatar
Re: Gas tanks?
If your tank has the big sender opening (about 4 inches in diameter ) you could just put an 87 sender and pump in it, but your tank wont have the baffle in it like the 87 stank.so you may have starvation problems when below half or quarter tank.
Bv
Old 06-04-2012, 09:59 AM   #13
nomrlz
nomrlz's Avatar
Re: Gas tanks?
i had bought a 99 Z28 tank for our swap but ended up buying a boyd tank instead of using it..
66 LWB/BBW work in progress
68 Camaro SS bigger work in progress
95 Roadmaster Wagon 12.36 @ 107.74
99 Hayabusa 8.72 @ 162
00 Hayabusa 9.33 @ 153
nomrlz is offline   Reply With Quote
Old 06-04-2012, 10:06 AM   #14
Kainedogg
Kainedogg's Avatar
Re: Gas tanks?
Thanks. I will use an inline walboro external for now with the c5 reg mod until I can find a good 87 tank.
Old 06-04-2012, 05:47 PM   #15
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Gas tanks?
So do you need a baffled tank to have the ls motors run properly? I was just going to run an aftermarket burb tank since i'm running a frame rail mounted pump.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 06-04-2012, 09:21 PM   #16
mooseknuckles
mooseknuckles's Avatar
Re: Gas tanks?
you dont have to run a baffled tank, but it is better if you do....it keeps fuel starvation to a minimum, when the fuel level is low, and you're on the throttle....I have a normal blazer tank, and I have to keep the fuel tank level above 1/8 if I'm gonna be foolin around....lookin back I wish I woud've bought the 87 blazer tank...
mooseknuckles is offline   Reply With Quote
Old 06-04-2012, 09:38 PM   #17
clinebarger
Re: Gas tanks?
I know a 87 sender fits a 77' & a 83' with stock tanks, Buy a 87' sender & put the pump in the tank. A inline pump doesnt fix the "fuel slosh" problem with unbaffled tanks. Your good to a 1/4 tank, You shouldnt run anything under 1/4 tank anyway.
clinebarger is offline   Reply With Quote
Old 06-04-2012, 10:17 PM   #18
Kainedogg
Kainedogg's Avatar
Re: Gas tanks?
Does it matter what tank? My truck only has one on the passenger side. Only reason I was going to use the inline and C5 reg is because I have them left over from another project.
Old 06-04-2012, 11:02 PM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Gas tanks?
If you have an unbaffled tank, get tank foam, it will aid in sloshing and help concentrate fuel around a sump (if you have a sumped tank). Either way it will help the slosh, as a fix.
Old 06-04-2012, 11:40 PM   #20
Kainedogg
Kainedogg's Avatar
Re: Gas tanks?
Forgive my ignorance but what is tank foam?
Old 06-05-2012, 08:12 AM   #21
CigarMan
Re: Gas tanks?
Forgive my ignorance as well please.
If I use one of these what else would I need to complete it for LS efi motor?
http://www.summitracing.com/search/Y...yword=gas+tank
Old 06-05-2012, 11:25 AM   #22
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Gas tanks?
With the 87-91 Blazer tank, you will need the same year sending unit and a high pressure GM style pump (EP381 or similar). The TBI pump from those years will not build enough pressure to support an LS. I would stick to the 25 gal if lowered, as the 31 gal will hang lower. Also note that this tank will not work on a SWB without serious hacking...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-07-2012, 10:00 AM   #23
Whittaker
Re: Gas tanks?
Tank Foam I believe is a way of baffling the fuel it is like a chunk of sea coral.
Whittaker is offline   Reply With Quote
Old 06-07-2012, 11:36 AM   #24
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Gas tanks?
http://www.evomx.com/fuel-tank-foam-information/
I didn't use this stuff in particular, but its a nice explanation. (I think the link is a mx racing company or something, just use it for the info)
Old 06-08-2012, 12:21 PM   #25
OldCreek
OldCreek's Avatar
Re: Gas tanks?
I used a 87 blazer tank in my blazer. I had to move the rear crossmember back a few inches. 87 sender with EP381 and stock filler.
I used a 89 Jeep tank in my C-10 long bed because I didn't want to move the crossmember. With this, I used a 87 sender with EP381. The Jeep tank fit pretty good...I added a small crossmember below the bed to have something the front end of the tank to rest on. The only issue is the filler size, 1". I'm running an in bed filler from the same jeep. The tank is barely visable below the rear sport bumper and otherwise would not be an issue if the truck were lowered.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
