Old 01-20-2012, 11:14 AM   #1
hotrodder
Thumbs up 283 -700r4 starter problems
I am installing a283/700r4 in my 63. After getting two wrong flexplates from Carquest, I called Summitt this morning and ordered one from them that supposely will work. I also asked about a mini-starter and the fellow said Iwill need a block plate adaptor to use one. My question is what is that , and where would I get such a part?
hotrodder is offline   Reply With Quote
Old 01-20-2012, 11:32 AM   #2
MikeN
MikeN's Avatar
Re: 283 -700r4 starter problems
My guess is that Summit sold you a small diameter flywheel. I'd forget the mini starter and just get a standard starter for a 153-tooth flywheel from carquest.
MikeN is offline   Reply With Quote
Old 01-20-2012, 07:32 PM   #3
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: 283 -700r4 starter problems
He may of said Starter Adapter Plate, or Mounting Block. It should come with it.
My dad order one for his 283 last year and it came with it. SBC 283/TH350.
On his car he used JEGS Performance Products 10001 - JEGS Prostarter Starter
http://www.jegs.com/i/JEGS+Performan...10001/10002/-1
JEGS Performance Products 60150 - JEGS Heavy Duty Flexplates
http://www.jegs.com/i/JEGS+Performan...60150/10002/-1
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 06-03-2012, 11:05 AM   #4
el_bole
Hotrodder,
Im going to be installing the same set up, 283/700r4, in my 61. What was the exact flywheel you ordered from Summit? I had a flywheel in the shed thinking it would work....NOT lol.....
Thanks,
el_bole
el_bole is offline   Reply With Quote
Old 06-04-2012, 01:56 AM   #5
Captainfab
60-66 Nut
If you use a 153 tooth flexplate you must use the starter for a 153 tooth flexplate (12-3/4" diameter). if you use a 168 tooth flexplate, you must use the correct starter for that (14" diameter). Either flexplate should work with the 700R4 torque converter as most flexplates come with both bolt patterns in them. A 283 is going to need the '85 and earlier flexplate for the 2pc rear main seal.
Old 06-05-2012, 02:11 PM   #6
61K10
61K10's Avatar
does your 283 have the starter mounted to the block? your starter bolts to the bellhousing right? the 700r has no starter provision for a starter. you need this adaptor for your stock starter. no mini starters for the B/Housing setup i know of. there are some good b/h starters out there though. do a google search for chevy 265/283 starter adaptor plate. also a 168t flexplate for the adaptor plate.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-05-2012, 03:24 PM   #7
el_bole
61K10,
On my 283 I have three mounting holes on the passenger side, on rear of engine. This is where the starter can be mounted......The original 350 I was going to install has no holes to mount a starter. So now Im going with a
700r4 which also has no place to mount a starter.
With that said why would one need that adapter plate if the block provides a place to mount a starter? Maybe that statement was directed to someone else on thread? Maybe I misread what you wrote. Help a brother out LOL.
Thanks,
el_bole
Old 06-05-2012, 03:30 PM   #8
el_bole
Hotrodder,
Did you ever get the flexplate from Summit? If so did it work, fit, for you?
Thanks,
el_bole
Old 06-06-2012, 12:30 PM   #9
61K10
61K10's Avatar
sorry i had it backwards--didn't know 283's had block mount holes. get the flexplate you want and yes a mini starter will work as long as the block holes are taped (threads in them) no adapter needed. the starter has the mounting plate built in--as pro/street pictures show. what was wrong with the flexplates from carquest?
1961 chevy K10
