Closed Thread
Old 06-06-2012, 11:18 AM   #4151
Clrussell
Clrussell's Avatar
Re: What did you do to your truck today!
Thanks for the compliment! I'm thinking about starting a build thread but the truck stays driveable 90% of the time and it wouldn't really be a build thread.. More like and upgrades along the way thread
61 apache
Clrussell is offline
Old 06-06-2012, 09:45 PM   #4152
Rob H.
Rob H.'s Avatar
I was smelling gas pretty strong the last couple times I drove the truck, I popped the hood when I got home from running to the store today, about 3 miles round trip. The truck had been running bad. I looked down and saw gas standing on the front of the crossmember. The new pump I'd put on 2 years ago was spraying gas out the weep holes. I pulled one off my 69 GMC parts truck and all is good now. Took it out for a little test drive, barked the tires in 4th for the first time. I guess the pump had been getting weak for a while!
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline
Old 06-06-2012, 10:14 PM   #4153
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
There was no electricity in the shop when I got there. So I mixed a 50/50 concoction of distilled water and Prestone to fill the radiator for the first time.
I was going to wait until I found the front brake line leaks before I put in any more fluids. But with nothing else to do without "juice", and with the fact that
I figured I better be able to discern coolant from brake fluid by this time in my life, I went for it.
Two quarts first.
Two quarts on the floor. The stuff passed right by an errant hose clamp on the lower rad. The clamp "read" tight. But there was a "dimple" in
the hose I couldn't see. Soooo...off with both tranny cooler lines, move the hot feed to the starter, and various other crap.
Never got it right today. Spent the rest of the time grinding off $50 worth of handles on the pass. side 'cause the clips were blocked by some really lame
door panel protectors.
Moved the hood back into the shop because the dog pulled one of the four panels of Dynamat insulation off of the inside while it was outside on saw-horses.
Next stop, electric windows on the pass. side. After I get done redoing everything else for the fifth time, that is.
Not my best day with the truck. At this rate, I should be ready to fire her off around December....... Of 2026!
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 06-07-2012, 01:26 AM   #4154
ItsRandy
ItsRandy's Avatar
Finished up a little more wiring, got my head lights back in the truck and working with the relay up-grade. One more thing to cross off of the list.
ItsRandy is offline
Old 06-08-2012, 03:06 AM   #4155
Mike Bradbury
Mike Bradbury's Avatar
Are you making the Brothers trip this year?
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline
Old 06-08-2012, 10:03 AM   #4156
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today!
I walked out to it , got in and drove off ~
As it's a tool it's time to go to work .
To - day will be light hauling , wheels to the Powder Coater and seats to the Auto Trimmer , both for my Metrpolitan Nash FHC .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 06-08-2012, 08:15 PM   #4157
ItsRandy
ItsRandy's Avatar
My truck probably won't be done but I'll be there.
ItsRandy is offline
Old 06-09-2012, 11:00 AM   #4158
RexDodge
Prepped the back sides of the welds (and panels) on my swb (cut down lwb) for a layer of reinforcing fiberglass. I'll lay that on today. Next week I'll finish and paint the back side of my bed panels. Then the bed is done, done, done...and ready for the bed liner anyway. Crap, things are never done are they.
RexDodge is offline
Old 06-09-2012, 06:31 PM   #4159
54belair
54belair's Avatar
Today I had to time to get back to work on it.
First thing I did was weld up the trim holes in the front edge of the hood, ground, sanded and ready for a skim coat of glazing.
Then I got back to working on the bed--- I have it sanded, stake pockets filled and smoothed. Today I started to work on the tail gate latches and the cables to hold the gate when down.
I have seen many guys ask how to add hidden latches (on a step bed) and how to handle the tail gate link issue. I am taking several pics as I weld, cut and finish the project and will add it to my project build before too long.
Tomorrow Ill remove the straps on the bedside where the chain ends go and finish grinding, sanding etc..
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline
Old 06-09-2012, 06:36 PM   #4160
Andy4639
Old member
Andy4639's Avatar
Wink Re: What did you do to your truck today!
magwakeenercew2jh,
I like your door panel's. They remind me of someones. I'm thinking about trying some regular leather on them next.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 06-09-2012, 09:54 PM   #4161
hgs_notes
GEARHEAD
hgs_notes's Avatar
I finished sanding and polishing wheel #2 of 4, put it on and drove around. Took the wife to the next town down the road for some shopping. 30 mile round trip with no problems. I need to rack up some more miles to work the kinks out. I need it to prove its reliability so I can take a road trip.
Before pic of that wheel...
hgs_notes is offline
Old 06-10-2012, 11:09 PM   #4162
ItsRandy
ItsRandy's Avatar
I now have twins (I painted my other fender).
ItsRandy is offline
Old 06-10-2012, 11:13 PM   #4163
Tmwoodall
Looks great, were you able to paint just out in the open of your garage like that, or did you have a booth?
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline
Old 06-10-2012, 11:19 PM   #4164
ItsRandy
ItsRandy's Avatar
I have plastic sheeting stapled to the roof framing, wet down the floor and spray away.
ItsRandy is offline
Old 06-11-2012, 12:54 AM   #4165
RexDodge
Started fabbing up the cover for the fuel filler inside the bed. I am using some scraps I have laying around. I should finish that tomorrow. I also hooked the filler and vent to the gas tank. Closer every day!
RexDodge is offline
Old 06-11-2012, 01:35 AM   #4166
dukcaln
dukcaln's Avatar
my son got his lic and is driving the 72 now so we added a clarion deck, alpine sub and alpine 6x9 some mids too..... just got to fab a box....... also added a new door hand ans fixed the roll down window........ darn 16 year old kid....
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline
Old 06-11-2012, 03:17 AM   #4167
Andy4639
Old member
Andy4639's Avatar
Going home yesterday morning. Took these with my Iphone. I drove the truck all week this past week.
Andy4639 is offline
Old 06-11-2012, 10:07 AM   #4168
Tmwoodall
Well, it looks great. I had all kinds of trouble getting a trash free coat in my garage even with sealed walls and ceiling of plastic, with wet down floor which is why I asked. Nice work.
Old 06-11-2012, 05:44 PM   #4169
VWNate1
VWNate1's Avatar
Friday morning @ 0-Dark:30 , I fired it up and drove to Torrance where I scored one of those $275.00 un cloggable Kohler toilets for FREEEE !!!!
Hey , I know this isn't sext but it's a my SHOP TRUCK dig ? .
Besides , I currently suffer greatly with some 35 year old toilet that ises 35 gallon per flush and usually need two or three go 'round before the bowl is clear...
Old men , we have different priorities .
-Nate
Geezer
VWNate1 is offline
Old 06-11-2012, 06:56 PM   #4170
69 gmc
69 gmc's Avatar
Had a SafeLite professional come over to help me remove the glass, it paid off because the glass isn't broken. I do have to find a new windshield gasket with the chrome trim groove though.
Calder
69 gmc is offline
Old 06-11-2012, 07:09 PM   #4171
mud.man.rj
mud.man.rj's Avatar
Just got my new tires and rims today. Pitbull Rockers 35/14.50/15" and MT ClassicII 12" rims, just need the flame job done tomorrow then I can install them, oh ya.
Truck is going to rock.
mud.man.rj is offline
Old 06-11-2012, 07:58 PM   #4172
ItsRandy
ItsRandy's Avatar
There's a little dust in the clear, nothing a little 2000 grit won't take care of.
ItsRandy is offline
Old 06-11-2012, 10:29 PM   #4173
Jarwood
Jarwood's Avatar
Got new wheels and tires! Ridler 695's 245/45/20 on front and 295/45/20 on back. I think my truck has a whole new look and I love it!
Jarwood is offline
Old 06-11-2012, 10:31 PM   #4174
Jarwood
Jarwood's Avatar
Before and After pics.
Jarwood is offline
Old 06-12-2012, 08:53 AM   #4175
Clrussell
Clrussell's Avatar
Made a to-do list for tonight and hopefully I get almost everything on the list done. If I do get everything done tonight all I'll like is unbolts to be able to drive er again
61 apache
Closed Thread
