Old 06-06-2012, 11:54 AM   #1
T2vigil
T2vigil's Avatar
Filler Neck Locations:
I am relocating the tank to under the bed and want to see where folks put their filler necks. I'e got a 64 short stepper and I don't want to do the in the bed Boat Filler Neck. Anybody have photos of other options such as fender mounts. Thanks.
T2vigil is offline   Reply With Quote
Old 06-06-2012, 12:20 PM   #2
CdM
CdM's Avatar
Re: Filler Neck Locations:
http://67-72chevytrucks.com/vboard/s...d.php?t=248460
i think alan put one in the bedside. youll have to look in his thread for it, but it was super clean.
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726
66 fleet lwb- In process
64 k10 10inch lift 38.5's- In process
92k1500 400hp on 38.5-parts truck now 8(
CdM is offline   Reply With Quote
Old 06-06-2012, 12:41 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Here's an earlier thread on the topic:
http://67-72chevytrucks.com/vboard/s...ht=filler+neck
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 06-06-2012, 03:10 PM   #4
McCoyAZ
McCoyAZ's Avatar
A friend of mine has a 64 step just like mine.
He re-located his tank to under the bed and brought the filler neck out the side of the rear fender behind the back wheel.
He picked up a gas cap door from a wrecking yard, cut it and welded it in place on his rear fender and it looks great.
Sorry I don't have pictures of it to post.
You can buy about any shape and style fuel door you want, his happens to be a small rectangular one.
Being it is a STEPSIDE you don't have the options these guys with fleetsides have.
McCoyAZ is offline   Reply With Quote
Old 06-06-2012, 03:54 PM   #5
lucifer
lucifer's Avatar
Put mine inside the bed with an electric door on the filler.
Works great and I don't have that marine filler sticking through the bed.
regards
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 06-06-2012, 11:06 PM   #6
k1rodeoboater
Behind the license plate. Used a Camaro tank under the bed
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
Old 06-06-2012, 11:08 PM   #7
jocko
jocko's Avatar
I like THAT approach the best personally (behind plate)
k1 - how many gal is the Camaro tank?
Old 06-06-2012, 11:19 PM   #8
siggyfreud
siggyfreud's Avatar
I want to say its a 16 or 18 gallon tank?
siggyfreud is offline   Reply With Quote
Old 06-07-2012, 07:46 AM   #9
k1rodeoboater
18. Same As stock. Only downside is ther sender is 0-90 ohm. Add a resistor or a pot and you can get it to work switch our stock gauge. It wont be linear, but from experience I know our gauges aren't the most accurate anyways
Old 06-07-2012, 08:54 AM   #10
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
I, too, like the rear fill tank idea. my donor truck came with one although I don't know what the tank came out of (I'm not sure it was even GM). I've been looking for something else. Here's a good source to use to check out tank dimensions: for instance dimensions on the '69 camaro tank:
http://www.gastanks.com/1969-Camaro-...ctinfo/GM-32B/
Larry
fleetsidelarry is offline   Reply With Quote
Old 06-07-2012, 11:41 AM   #11
T2vigil
T2vigil's Avatar
I should have asked for these ideas before getting the Blazer tank since I do like the rear filler tank idea. So I will be doing something out the side and mounting the filler on the fender.
Old 06-07-2012, 05:54 PM   #12
k1rodeoboater
My how to is posted under the sticky. If the pics don't work I will have to go back and fix the links
Old 06-07-2012, 09:09 PM   #13
1966c10shrtbd
1966c10shrtbd's Avatar
This is where I just recently changed mine to.
1966c10shrtbd is offline   Reply With Quote
Old 06-07-2012, 11:28 PM   #14
Johnny Too Bad
Johnny Too Bad's Avatar
I have my tank under the bed and my filler neck on the driver's side fender. Sorry about the crappy cell phone pics.
1964 Chevrolet C10 SWB Stepside (350cid/TH400)
1978 Chevrolet C10 SWB Silverado Big 10 (454cid/TH400)
-"Ah, the pressure's fierce!"
Johnny Too Bad is offline   Reply With Quote
Old 06-07-2012, 11:42 PM   #15
McCoyAZ
McCoyAZ's Avatar
Johnny:
What was the filler door off of that you used for you truck?
Old 06-08-2012, 01:02 AM   #16
Johnny Too Bad
Originally Posted by McCoyAZ View Post
Johnny:
Sorry McCoy, I'm not really sure. I got it from a buddy who had several he had collected from junk yards over the years. He thinks it may have come off of an older (late 80's or early 90's) Toyota Camry but he's not positive. It's smaller than the one I had originally planned to use off of a mid '80's Chevy fleetside, which was too wide for the top of the fender on my '64 step.
Old 06-09-2012, 10:15 AM   #17
T2vigil
T2vigil's Avatar
Johnny, thanks for the photos. Do you have any photos of the underside and what type of hoses did did you use?
