Old 04-13-2012, 12:07 AM   #1
stratron
1963 C20 disc conversion
To convert my 1963 C20 to front disc brakes, do I need the front crossmember from the donor 1977 C20, or will the 1977 lower A-arms connect OK with my existing crossmember?
stratron is offline   Reply With Quote
Old 04-13-2012, 12:59 AM   #2
Captainfab
60-66 Nut
Re: 1963 C20 disc conversion
On the '60-'66 C20's you have to change the crossmember also. This is because the '60-'66 C20's have a flat lower control arm shaft, whereas the '67-'87 C20's have a round shaft. Compare the two where they mount to the crossmember and you will see what I mean.
Old 06-08-2012, 01:05 AM   #3
stratron
Thx!!
