06-03-2012, 11:47 PM | #5501 |
Re: What did you do to your truck today?
Finally finished the process of painting the wheels that I bought. The wheels are from a late 70's early 80's 4x4, they were originally white, and had center caps only (mine didn't have them when I got them mind you). I had a 71 Cuda with factory rally wheels a long time ago. They were a similar design to these, except the center section was inverse. I think the similarity in design
is what attracted me to these wheels. First I had a buddy machine the center hole in each rim out to 3.625. Don't recall the exact beginning dimension, but the dimension was about 0.020 too small, and they would not fit over the hub front or rear. Second off to the sandblaster. At first I was a little upset as the finish after blasting was very, very rough, and all of the rust was not gone. While I used rust converter (applied liberally), I put on my thinking cap as to how to deal with the rough finish. Medium steel wool is what I tried first, and I was very pleased with the result. The rust converter seemed to do it's job... so I did mine, man I am sore... steel wool + 5 wheels (all surfaces) = one day of hard labour. I was also left feeling a little unsure as to how the paint would end up looking. So, off to the laundry tub for a good scrub with soap and water, towel dry, a liberal application of One Choice wax and grease remover. Two coats of primer, and three coats of semi gloss black, and I am very happy with the result. Tomorrow, ordering the rubber, hoping to have them on by the weekend. I am a hot rodder at heart, so big ones back there, and littler ones up front. Next up, beauty rings, and center caps!
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
06-03-2012, 11:48 PM | #5502 |
Chevy Only Tx
This !!!!!!!!!!!!!
Chevy Only Tx......... |
06-04-2012, 02:01 AM | #5503 |
Senior Enthusiast
Excellent, I really like how they turned out. Looking forward to seeing them on your truck.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
06-04-2012, 10:01 AM | #5504 |
Me too! Undecided on the tire sizes, either 275/60R15's on the back, and 225/70R15's on the front, or 295/50R15's on the back, and 235/60R15's on the front...
06-04-2012, 02:48 PM | #5505 |
Retrofitted the fan shroud off of my '77 350 sbc parts truck and installed in my '64. A lot of notching and I had to fab some brackets, but it fits and works well.
1964 Chevrolet C10 SWB Stepside (350cid/TH400) 1978 Chevrolet C10 SWB Silverado Big 10 (454cid/TH400) -"Ah, the pressure's fierce!" |
06-04-2012, 03:26 PM | #5506 |
Finshed the grill and got the new rear window rubber in. More pics on my build thread
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
06-04-2012, 03:52 PM | #5507 |
Senior Enthusiast
Should you be interested in something to compare against, I’m running 255/70’s on the rear and 215 /70’s on the front, all on 15x7” wheels. The Fleetside bed accommodates much wider rear tires than the stepside. As a diameter reference my front tires are 26.89” tall and the rears are listed as 29.1” tall.
06-04-2012, 09:50 PM | #5508 |
Got the '85 donor crossmember bolted in...
06-04-2012, 10:05 PM | #5509 | |
06-04-2012, 10:22 PM | #5510 |
Wired up my heater and then put in the defroster hoses!
86 K20 6" lift 66 C10 LS2 T56 1947 Ford Rat Rod Softail Deluxe Softail Chopper |
06-07-2012, 06:24 PM | #5511 |
Dropped spindles and rear springs came in today, gonna be an interesting weekend!
06-07-2012, 08:06 PM | #5512 |
Finally finished mounting the bed and took it for the first drive in 20 years!!
Wow! I forgot how much i love this truck! I need to tidy up a few things and get the tailgate painted etc. But i am super happy |
06-07-2012, 08:12 PM | #5513 | |
Looks great! Congrats on her "maiden" voyage..... el_bole |
06-07-2012, 08:15 PM | #5514 |
Congrats Raked 64 that must be a blast I cant wait till I can take my build for its first drive.
12ram3500 HS mm, FP 5" tbe, SB cai, 2.5" up, 35s on 20s. SOLD 02ram2500 twin turbo, built 47re, sticks & studs : SIKDZL -youtube. 68gmc1500 soon to be: shortbox, ppumped 24valve, s467.7, dap 300s, H2O/Air intecooled, meth controlled, 47re, 14bolt, 2wd. |
06-07-2012, 09:59 PM | #5515 |
AWESOME, CONGRATS, must have been a great feeling, let's see some more pics of "finished" product!!!!
06-08-2012, 09:53 PM | #5516 |
Got a couple of steering wheels painted and assembled.
06-08-2012, 09:57 PM | #5517 |
Chevy Only Tx
Just curious do you sell them or are the for your personal ride?.... They look good!!!!... I like the one on top
06-09-2012, 05:52 PM | #5518 |
Just cut and buffed the hood.
06-09-2012, 05:56 PM | #5519 |
been working on a bunch of small items, its taking me forever theres alot of parts you dont realize that need to be cleaned or finished if you are going to do it right .painted these bad boys up still need glass and weather strip
STEVES 63 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=412554 GIBSON63 YouTube channel https://www.youtube.com/user/1gibsonl4 |
06-09-2012, 05:57 PM | #5520 |
06-09-2012, 06:53 PM | #5521 |
Those look sooo nice! I need to do that on mine as well, but haven't had the will to undertake it.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
06-09-2012, 09:13 PM | #5522 |
1 thing at a time is progress.
Nice work, Steve
Alan
Philippians 2:14-16 |
06-09-2012, 09:59 PM | #5523 |
Senior Enthusiast
Dove into the struggle with the vinyl floor mat today. Time will tell how nice it turns out, but it is without question the most difficult installation I've ever encountered. It's like trying to wrestle a sheet of ABS plastic into the shape of a truck floor!
06-09-2012, 10:11 PM | #5524 |
finished the patching of the passenger side inner fender.
Then my son and I cleaned them up along with the core support and shot on 3 coats of hammer paint on the driver side one and the core support. It looks fantastic! I have to make a few comments on this paint: First, it covers incredibly well. Second, it is very very easy to spray when you thin it 20% with acetone. Third, it covers imperfections way better than I expected. The only drawback is that it dries slow. It took over 7 hours to stop being tacky. Luckily it won't be bolted back together for at least two months so it will have plenty of time to dry. I ran out of paint and have to paint the other one tomorrow. I will take pics then as well because I forgot my camera today. Steven
Life is and will ever remain an equation incapable of solution, but it contains certain known factors. - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life? http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
06-09-2012, 10:16 PM | #5525 |
.Mark did you lay it out in the sun before hand....?
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
