Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 05-18-2012, 07:40 PM   #201
benoit454
Chris
benoit454's Avatar
Re: My 88 buildup on a tight budget
I have to second coat it all tomrrow. Then maybe I can put stuff back together.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 05-18-2012, 08:06 PM   #202
tecky11
wow the rotors got rusty fast, loots good tho
Truck: 1972 International Harvester 1210
Engine: Caterpiller 3116 220 HP 630 tq
Transmission: Eaton Fuller rt 6610
Axles: Merritor I beam front axle
tecky11 is offline   Reply With Quote
Old 05-18-2012, 09:11 PM   #203
benoit454
Chris
benoit454's Avatar
yea as soon as water hit them bam rusted instantly. I plan to knock the rust off and then clean them with brake clean before use for sure.
Chris
GIT R DONE!!!!!!
Old 05-18-2012, 09:13 PM   #204
tecky11
or replace them since they are out
Old 05-18-2012, 10:02 PM   #205
benoit454
Chris
benoit454's Avatar
I don't think so. notice the title? tight budget? I spent my last $20 buying brake hoses and sway bar end links. I'd like to buy new ones or just have these resurfaced.
Chris
GIT R DONE!!!!!!
Old 05-18-2012, 10:15 PM   #206
tecky11
lol true looks great tho
Old 05-18-2012, 10:24 PM   #207
benoit454
Chris
benoit454's Avatar
thanks, be alot better once I get my paint on lol.
Chris
GIT R DONE!!!!!!
Old 05-19-2012, 09:22 AM   #208
Ricky78045
Ricky78045's Avatar
How many cans did it take to paint all those? Looks really good
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road...
1988 Chevrolet Silverado Single Cab, Short bed, 350, 5.7L: daily driver/on a budget restoration
Ricky78045 is offline   Reply With Quote
Old 05-19-2012, 12:04 PM   #209
benoit454
Chris
benoit454's Avatar
less then one. it's a quart of oil based rustoleum. I only used a little over half.
Chris
GIT R DONE!!!!!!
Old 05-19-2012, 08:08 PM   #210
benoit454
Chris
benoit454's Avatar
2nd coat on the front end, and then installed all 4 balljoints and reinstalled the knuckles....
Chris
GIT R DONE!!!!!!
Old 05-23-2012, 10:22 PM   #211
BIGphillip79
BIGphillip79's Avatar
Did you pull the front end apart just for paint?
That's dedication.
If it ain't broke broke don't fix? Get a hammer.
'89 K1500, Reg. cab/long bed, 350/700r4, 285/75-16.
BIGphillip79 is offline   Reply With Quote
Old 05-24-2012, 08:03 AM   #212
benoit454
Chris
benoit454's Avatar
yea clean up and paint, but the steering stuff was to replace it all, new balljoints, tie rods, idler arm.
the diff. I took out to clean and paint but I got seals coming for it. I'm gonna fix the leaking axle seal and pinion seal on it.
I got the rotors, pads, and calipers put on yesterday, then fought the sway bar end links, and also fought the grease fittings. Now it's greased up and the brakes are on, even got the new brake hoses on it.
Chris
GIT R DONE!!!!!!
Old 05-24-2012, 05:18 PM   #213
BIGphillip79
careful when you pull the axles for the seal. In the long end there is a washer/spacer that goes on the little bearing race on the end of the axle shaft. you wanna make sure that's in place. Mine fell and I didn't know it was there and it chewed the hell out of some bearings.
Old 05-24-2012, 09:31 PM   #214
benoit454
Chris
benoit454's Avatar
I got t all apart and put back together but the seals are wrong. the seal that was leaking wasn't a bad seal, just wasn't sealing to the housing like it's too small of dia. just barely to make it tight enough to be a press fit. it goes into place easy.
The pinion seal i got it too small too.
I got the wrong part number for it, but the axle seal is the one everyone calls for and it won't seal up to the housing right.
Chris
GIT R DONE!!!!!!
Old 06-01-2012, 10:03 PM   #215
benoit454
Chris
benoit454's Avatar
I haven't taken any pics but it's all back together, just working on setting the toe, then have to tighten the sway bar end links, fill fluids, like diff. brake, and then power steering. I also of course have to bleed all the brakes. Then I need to do the body work on my inner fenders to get them ready.
Chris
GIT R DONE!!!!!!
Old 06-05-2012, 09:51 PM   #216
benoit454
Chris
benoit454's Avatar
front end is back together, have to do all the fluids and bleed brakes and such though. Also check toe and have an alignment done, but for now I started on body work underhood.
I sanded and primed the inners and then painted the underside of them same as my frame, then did the back of the fenders and firewall, doing all the body worked areas, fan shroud and rad. support in body color.
Chris
GIT R DONE!!!!!!
Old 06-05-2012, 11:35 PM   #217
Ricky78045
Ricky78045's Avatar
Looking good, makes me wanna paint my inner fenders!
Old 06-05-2012, 11:44 PM   #218
benoit454
Chris
benoit454's Avatar
yea you should lol. j/k
Chris
GIT R DONE!!!!!!
Old 06-06-2012, 08:56 PM   #219
benoit454
Chris
benoit454's Avatar
found somethings a bit interesting tearing down the front, well removing the fender.
that doors been hard to shut and makes a loud pop when it catches you have to pull hard, roller pin is bent bad. I knocked it out, going to order a new one for both sides. The ds has been missing as well as the ds door spring since I got the truck.
Also notice anything wrong?
yea removed that bolt and that come with it. It's broke clean off and has been for quite some time, has rust on it, no clean metal.
Now that I kept yall waiting long enough, I got some PAINT ON!!!!!!!!!!!!!!!!!
Chris
GIT R DONE!!!!!!
Old 06-07-2012, 09:04 PM   #220
benoit454
Chris
benoit454's Avatar
more work done today..
Chris
GIT R DONE!!!!!!
Old 06-10-2012, 07:05 PM   #221
benoit454
Chris
benoit454's Avatar
couple pics of the flake
Chris
GIT R DONE!!!!!!
Old 06-11-2012, 01:40 PM   #222
75ChevyGuy
GM Parts Guy
75ChevyGuy's Avatar
This truck has definitely come along way! I like the way the underhood is looking.
1975 Chevrolet C-10 Custom Deluxe (DD/WIP)
1989 Chevrolet C1500 reg cab stepside (Winter Truck)
1977 Harley Davidson XLH 1000 (Summer Cruiser)
75ChevyGuy is offline   Reply With Quote
Old 06-11-2012, 02:31 PM   #223
benoit454
Chris
benoit454's Avatar
thanks, I'm looking forward to getting it back together, and doing the rest of the truck.
Chris
GIT R DONE!!!!!!
Old 06-11-2012, 05:36 PM   #224
Dub_X
Professional Crow Bar Tosser
Dub_X's Avatar
It's coming along good. I didn't notice if you had mentioned this or not, but are you gonna end up painting the truck blue when it's all said and done? Because the blue is looking damn good on your parts.
Dub_X is offline   Reply With Quote
Old 06-11-2012, 08:08 PM   #225
benoit454
Chris
benoit454's Avatar
yes sir the entire truck is going to be that same blue. going to do behind the cab and bed, door jambs, bottom of the hood and the entire outside, bedline the inside of the bed, maybe throw in some matching blue inside the cab.
Chris
GIT R DONE!!!!!!
