Can't get my Aeroquip A/C lines to stop leaking
I plumbed my Vintage Air system using Aeroquip A/C lines. My #6 and #10 lines seal with no problem. The #8 coming off the high side of the compressor has been driving me crazy. I have two fittings leaking on the back side of the fitting where the hose enters (red circle). I pulled it apart and reassembled it with no luck. I had other leaks in this same section of hose. When I fixed those these popped up. I made sure to replace the o-rings when I took it apart. If I move the hose there is a small hissing noise in the circled areas.
Is there a trick to getting these fittings to seal? ![]()
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() |
Re: Can't get my Aeroquip A/C lines to stop leaking
had this same problem with my power steering lines they were exact same ones i found a local place that made hydraulic lines etc.. most of these places make braided lines as well took mine in cost 25 bucks they duplicated it and now im leak free
1971 rs camaro under the knife ls3 6 speed swap 1970 396 big block shorty fleet 67 clone 2010 rs/ss camaro |
