Old 05-23-2012, 11:00 PM   #1
1970ChevyChamp
1970ChevyChamp's Avatar
12 bolt rearend, 6 lug to 5 lug
I have a 6 lug 12 bolt truck rearend with 4:11 gears in my truck now. I am wanting to convert over to 5 lug. I have a couple spare 12 bolt rearends with 5 lug axles in them. Can I just pull the axles out of the 5 lug parts rearend and put them into the rearend that originally had the 6 lug in it? If so or if not what do I need to do? Thanks
1970ChevyChamp is offline   Reply With Quote
Old 05-23-2012, 11:18 PM   #2
kaycee
kaycee's Avatar
Re: 12 bolt rearend, 6 lug to 5 lug
For the most part yes you can,they changed the rear end width mid 70's sometime.Measure the width from face of drum to other face of drum and see if the width is the same,if so then they will swap over.I had a narrow rear and used wider axle's,I made a 3/4" spacer to go in between the backing plate and axle housing. the rears are 1 1/2" differance between the 2 ,been running it hat way for 5 yrs and no problem.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 05-24-2012, 12:04 AM   #3
1970ChevyChamp
Alright thanks! I knew there was some kind of catch to doing it.
Old 05-24-2012, 12:56 AM   #4
leddzepp
Moderator
leddzepp's Avatar
If your truck's rear end is a 1970, there is a good chance that it has the wider housing, and 5 lug axles would pop right in with no problem.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-24-2012, 02:42 AM   #5
1970ChevyChamp
It is actually in a '67 pickup, but I am pretty sure that one of the extra 12 bolts I have is out of a '69 if I'm not mistaken. Oh well, I guess I'll have to let the tape measure do the talkin!
Old 06-10-2012, 08:32 PM   #6
1970ChevyChamp
What I have is the shorter '67 12 bolt and my extra parts rearends are the newer style longer housings. What should I do to convert to five lug? I would prefer to stick with the shorter housing so I can fit bigger tires, or should I just out one of the newer style housings under there?
Old 06-10-2012, 09:20 PM   #7
chiefcfd
chiefcfd's Avatar
If you have access to a mill I am pretty sure you can redrill your axles to 5 lug
chiefcfd is offline   Reply With Quote
Old 06-10-2012, 09:32 PM   #8
3rdGen.c10
3rdGen.c10's Avatar
you can buy the five lug conversion axles online. summit has moser 5 lugs for those rearends. thats what i did and theyre sweet. or cpp has conversion kits with everything you will need.
1967 c10 stepside 6.0L 4L80E
3rdGen.c10 is offline   Reply With Quote
Old 06-10-2012, 09:32 PM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
Aftermarket 5-lug axles is your answer.
Moser Engineering or Early Classic Enterprises can fix you up.
Keith
Convert to disc brakes.
Old 06-10-2012, 10:25 PM   #10
mbgmike
we sell the axles. We also shorten and respline axles, housings, build pro stock rear ends from scratch ,redrill and plug etc. Just for info.
I think we are 90 to redrill and 50 to plug and pair of axles
mbgmike is offline   Reply With Quote
