Old 06-11-2012, 01:36 AM   #1
Rusty one
Rusty one's Avatar
Front sheetmetal question
I'm ready to pull my engine & trans to get it ready for a dropmember. Thinking it would be easier to take the front end sheet metal off first. The hood is easy enough but cam someone tell me where the bolts are located to pull the nose off in one piece.
Thx in advance.
Rusty one is offline   Reply With Quote
Old 06-11-2012, 09:26 AM   #2
Clyde65
Clyde65's Avatar
Re: Front sheetmetal question
two or three bolts at the firewall, couple bolts under the cowl panel, one bolt inside fender well by exh manifold, one bolt lower rear fender. I think thats it.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-11-2012, 10:22 AM   #3
padresag
you forgot the two under rad support
ron
padresag is offline   Reply With Quote
Old 06-11-2012, 10:26 AM   #4
bonacker
Also disconnect the wiring harness.
bonacker is offline   Reply With Quote
Old 06-11-2012, 11:36 AM   #5
padresag
and the small sheet metal piece on the lower inner fender below the str column and the rad hoses
ron
Old 06-11-2012, 01:26 PM   #6
Rusty one
Rusty one's Avatar
Thanks for the reply's. Is there a link for the location of the nuts & bolts?
[size=1d]Posted via Mobile Device[/size]
Oh yeah the wiring harness? Does that just unplug from the firewall?
Old 06-11-2012, 02:08 PM   #7
padresag
you have to learn how to do some of these things for yourself. if you are going to continue to work on these things, that is how you learn . trying to figure things out for yourself. these vehicles are not complex
ron
Old 06-11-2012, 03:02 PM   #8
Clyde65
Clyde65's Avatar
I have to agree with Padresag, however, be sure to bag and tag the bolts/nuts and small pieces so your project can go back together.
Clyde65
Rebuild of Clyde
support our troops!
Old 06-11-2012, 04:13 PM   #9
Rusty one
Rusty one's Avatar
Thx for your tip
