Old 06-11-2012, 02:11 PM   #1
chevy72blu
chevy72blu's Avatar
How are you guys tackling accesories? (Factory air/PS 72')
Here I am with more questions (that tend to have expensive answers).
How are you guys dealing with components?
My plan is to take a complete 5.3 along with all accessories - Alt, PS pump, AC compressor and install it with the factory equipment as best as possible.
It seems like no one is having issues with the brackets/accessories clearing, so thats a good start.
My 72' is a factory air, factory P/S. Is there any faq or write up regarding connecting the new compressor from the 5.3 into the existing air setup? I pulled my evaporator/condenser a while ago along with the compressor but I still have all of the parts. Can these parts even be reused with the modern compressor, or do I need new stuff? Im sure the connections are different sizes/locations. Who should I talk to?
As for the P/S, same question. Do I just have a hose/hydraulic shop press new fittings and connect the pump to the steering box?
I converted my alternator to 1 wire a while back - I'm hoping this will be a straight plug and play.
Thank you! This subforum has been an incredible resource to wrap my head around this swap.
chevy72blu is offline   Reply With Quote
Old 06-11-2012, 06:06 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: How are you guys tackling accesories? (Factory air/PS 72')
cant say as for a/c....but for ps just slip this in the pressure side of the pump and connect your hose.
adapter
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-11-2012, 06:52 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Or, with a 1" wrench, remove the fitting from the back of your old ps pump and install in the 5.3 pump. It's the same style pump, just with a different reservoir. Cost: free.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-11-2012, 08:53 PM   #4
68GMCCustom
ah da...I had a cheap solution but not free... you got me there.
Kurt -
Old 06-11-2012, 10:12 PM   #5
clinebarger
You can run the factory Denso compressor. Or run a Sanden compressor....http://www.alangrovecomponents.com/LS.htm.
Adapter blocks seem to be hard to find for the Denso lately??
The factory evaporator used a expansion valve/POA valve, To make this work well...You need a NOS/Delco POA valve & R-12.
To use 134a you need to delete the POA valve, Kits available.
I retrofit later Orifice tube/Accumulator evaporator cores in these trucks....77 Olds 98 evaporator cores fit in 69-72 cases.
A Vintage Air A/C/heat kit With a Sanden compressor works really good.
clinebarger is offline   Reply With Quote
Old 06-12-2012, 10:03 AM   #6
mooseknuckles
mooseknuckles's Avatar
x2.
mooseknuckles is offline   Reply With Quote
Old 06-12-2012, 12:53 PM   #7
chevy72blu
chevy72blu's Avatar
Thanks for the tips!
Thats great news on the PS pump.
As for the AC, I have the complete R12 setup but it would be nice to run the much easier to find 134a.
Will the factory compressor fitting connect to the Denso compressor?
I've made a few calls around town but no one seems to know anything about these older AC systems.
I assume the alternator is a non-issue, also?
Thanks again
Old 06-12-2012, 04:01 PM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
Alt should be computer controlled. You will need to hook up your charging cable to the battery. A/C could be as simple as having new hoses made-- people have had varying success with the variable displacement compressors.
-Chris
Old 06-17-2012, 01:18 PM   #9
short-t
short-t's Avatar
Do you have any pictures of the Olds evaporator in our trucks? Thanks, Greg
1968 C10 LS2/4L70e swb fleet side. ECE front disk conversion and 3.5/5 drop. SOLD.
1968 C20 Custom Camper 396 50th survivor! SOLD to northerngmc
short-t is offline   Reply With Quote
