Manual Trans Installation?
Thinking of swapping out my 4L80E for a manual trans behind my LQ9.
What have you guys installed that DIDN"T involve cutting the trans tunnel in the 2WD truck? Truck is all done so I don't feel like having to strip the interior and cut the tunnel out and everything that goes along with that. Also, what have you used for a hydraulic clutch set up? (mount, etc) Thanks
Tim Baillie Installer/Designer/Fabricator Trick Factory Customs Company - www.trickfactory.com Personal - www.hzemall.com Instagram - @hzemall |
Re: Manual Trans Installation?
ok time for my long story... maybe.
I have a 5.3 and had the 4l60 behind it for a few years. After a couple power adders it decided to start slipping. I had a T56 in the waitings so that was the plan to swap in. I am getting my final hose made today so hopefully it will be moving again under its own power soon. That will be the best idea for a swap. For a little history I did the 5.3 gen 3 swap about 7 years ago before most were doing it or there were too many mounts so I made my own, they are low and back far. I was able to set my engine tranny angle at around 3.5 to 4 degrees down in the back and am using my low hump cover so it is possible atleast on mine but it is very very close. I am using my stock 400 turbo mount with just about 3/4 inch cut out of it. I hope to know soon if my hydraulic clutch works I mounted a S10 master cylinder on my firewall and ran into the top of my clutch pedal, it seems like it has the right throw but again I will soon know. the hose became the thorn in this process. I am using the factory 2002 camaro slave cylinder and the hose in mysetup is too short, I am using the stock "plug" or fitting on the slave, this probably would be best changed to find the right hose. I will post more later.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Thanks for the info, keep me posted.
I noticed in the LMC catalog that in 86 the C-10 had a hydraulic clutch system, would something like that work better?
Always a work in progress
If you are looking for a complete package you could contact Keisler engineering or one of those companies. I looked into a while back and they have kits that will work with our trucks.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
They don't make one.....just cars
ok an update. I got the T56 installed. I did use the low hump but it was or is extremly tight. Originally I cut the floor out for the high hump but ended up getting the stock one to work. I built my own motor mounts and modified the tranmission cross member. I stuck my motor as low as possible so that may have helped. I doubt it will work with some of the purchased mounts but am not sure.
The T56 is sure fun, and seems to work really good with my 3.73 gears. I cruise at 1500 rpm at 70 mph. a lower set of gears might be a better option as first still seems a little high. All in all it is a great swap. Dave
![]() Join Date: Nov 2007
Tim,
Like Custom 68 says. The T56 is a lot of fun in my 65. Low hump floor, tight but doable. Pictures and details in my build thread. Good luck, TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
| Bookmarks |
