06-11-2012, 07:09 PM | #1 |
"something witty here"
bbc sm465 question
Im doin a bbc swap into a 68 4x4 I have a sm465 with a np205 from a small block I would like to use, do I need a new bellhouse or is the bellhouse the same for both?
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
06-11-2012, 09:01 PM | #2 |
Re: bbc sm465 question
IIRC the bellhousing should be the same for both.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
06-12-2012, 12:57 AM | #3 |
yep, bolt em up. your z-bar may be different. look into that perhaps. otherwise there is no issue.
have fun with the new big block!
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
06-12-2012, 08:33 AM | #4 |
Bell will work.
I have heard of problems with valve covers hitting the fire wall and the frame having to be notched for exhaust manifolds/headers. I've personally never did the swap so i have no 1st hand experience.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
06-12-2012, 09:48 AM | #5 |
oh ya, thanks for the reminder. Some have valve cover clearance issues and some do not. If you plan to run full roller rockers you'll need to use tall valve covers to clear them, this is where most people run into firewall clearance when converting to a big block. When i do it again i will move the motor to the forward set of mounting holes on the frame and extend the drive shaft. This will alleviate a lot of the clearance issues with both the covers as well as the tight fit for an HEI dizzy. -steve
