Old 09-27-2003, 12:08 AM   #1
1969 GMC
1969 GMC's Avatar
door wont open
hey guys, I have been getting a little bit of a problem from the GMC lately. when i go to open the driver door from the outside, the button depresses but doesn't open the door. the inside handle does not work either for this. i found the only way to alleviate this is to push the lock button down (hard to push) and then pull it back up, and then the door will work fine on both sides. it has gotten worse and worse, now i pushed the lock knob down and it bent a little bit, wont pop up, and the door wont open from either side. I am gonna tear into the door tomorrow morning, any advice before hand on what I should do to fix this? tia
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 09-27-2003, 03:08 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Sound's like you need a new door latch. Maybe check to make sure it is not all screwed up..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-27-2003, 03:11 AM   #3
Phillip Johnson
Phillip Johnson's Avatar
Put a Chevy grill on it and it will be ok in the morning.. Just kidding
Phillip Johnson is offline   Reply With Quote
Old 09-27-2003, 12:22 PM   #4
1969 GMC
1969 GMC's Avatar
ha ha .... ttt
1969 GMC K2500
1996 Honda Accord
Old 09-27-2003, 11:33 PM   #5
big blue 72
that's why they make bench seats.
slide on out the other door.............................
big blue 72 is offline   Reply With Quote
Old 09-27-2003, 11:48 PM   #6
68 Stepside
huh?
68 Stepside's Avatar
if you have to lock it, then unlock it, and the lock is hard to push...try using some white lithium or something, and lubing all the latch mechanisms up inside the door.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 09-28-2003, 11:29 PM   #7
1969 GMC
1969 GMC's Avatar
thx 68 stepside...i didn't get a chance to look at it yet (2 day date, whoa) but i was thinking along those lines. sliding across the seat is getting old, it wouldn't be so bad if i had a 2wd automatic, but i have a 4 spd 4 wheel drive, so its like a jungle of shifter levers i have to shove my legs thru, and im 6'4" so its not fun at all.
1969 GMC K2500
1996 Honda Accord
Old 09-29-2003, 12:17 AM   #8
highboy_04
highboy_04's Avatar
i say all you need is lube
'67 c10 350/th350
highboy_04 is offline   Reply With Quote
Old 09-29-2003, 01:06 AM   #9
1970blazin
Blazerless:-(
1970blazin's Avatar
Highboy..."all you needs is lube" to get across the seat and out the door....:p or "all you needs is lube" to fix the door LMAO!!!
1970blazin
1970 CST Blazer-Orig. Dark Blue-SOLD
Progress Pics of Blazer for sale
1970blazin is offline   Reply With Quote
Old 10-01-2003, 07:33 PM   #10
1969 GMC
1969 GMC's Avatar
well i finally got the 3 hour job from hell done. i opened up the door, and found out that basically the mechanism just needed some lube. it was workin ok, then i slammed the door and it wouldn't shut, just bounce back open. i have to disassemble the mechanism and discover that about 3 pieces of it are missing.
a little work with a magnet and i find all the pieces in the bottom of the door. the rivet that holds that catch that the outer door button presses had fallen out of the mechanism, and the catch, spring, and rivet fell into the door, letting the gear on the catch just spin. now I am done (finally) so if your doors are acting up, check the rivets in the mechanism!
1969 GMC K2500
1996 Honda Accord
Old 10-01-2003, 09:24 PM   #11
highboy_04
highboy_04's Avatar
1970 blazin i was thinkin a little bit for both. lol
'67 c10 350/th350
