Old 06-12-2012, 04:30 PM   #1
chewychevy67
weights on front drum and hub question
i am going to get my original drums turned and was curious if i remove the hub from the drum will it set the weights off? one has a weight and one doesn't. Rod.
chewychevy67 is offline   Reply With Quote
Old 06-12-2012, 04:41 PM   #2
terry b
terry b's Avatar
Re: weights on front drum and hub question
The weight is there to balance the drum. It got balanced before it got put on the hub. Those drum's have got to be shot by now unless low mile's.
terry b is offline   Reply With Quote
Old 06-12-2012, 04:46 PM   #3
chewychevy67
i just talked to 2 brake shops and said there are very turnable. not sure on the mileage but they still look fairly thick with next to no ridge. i hear the new ones aren't as good as the originals so i would rather use these. so i can remove them without a problem then. Thanks.
Old 06-12-2012, 05:15 PM   #4
chewychevy67
should these be left together? is there a reason gm did this? maby to make sure when you checked your front brakes you had to check your bearings at the same time. just for maintenance?
Old 06-12-2012, 06:06 PM   #5
hayhauler71
hayhauler71's Avatar
Have them resurfaced with the hubs attached they will be more true
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 06-12-2012, 07:48 PM   #6
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
true
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-12-2012, 08:02 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Yeah don't remove them from the hub.. I just had mine surfaced last year and I was told to bring them in with the hub.
68gmsee is offline   Reply With Quote
Old 06-12-2012, 08:50 PM   #8
chewychevy67
i think i will leave them together. thanks for the info
