Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-10-2012, 02:04 PM   #1
dbmx66
dial board mounting ideas
how to guy have you dial-in boards mounted.
i was going to mount mine in the window. but im making removable lexan side windows, that are going to be dzus pinned on, so if i wanna cruise on a nice day i can take the window out. I dont feel like messy around with window paint to write the numbers on either, so thats not an option
so if the dial board was on the window, it would come in and out with the window. i just want to keep the window as light as possible. because only dzus pins are holding it.
do i mount it too the door on the bottom or top window opening? then itll be there all the time, even with the windows out?
or to the roll cage in the window opening?
lets see how some of you do it. or any ideas?
thanks, dave
dbmx66 is offline   Reply With Quote
Old 06-12-2012, 02:44 PM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: dial board mounting ideas
My first thought would be something light like small thin wall tubing with tabs welded to it . Bend 90's on the ends and weld small machine nuts to the ends of the tubing . Drill the lexan and counter sink machine screws or just use button head allens with stainless washers and mount it to the window That way it goes with the window . Next would be a pin in or bolt in to the cage . Last would be to the door frame . JMO .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 06-12-2012, 09:58 PM   #3
dbmx66
Ive been thinking and i tgink thats what im gonna try
