NEED HELP Ramjet 350 base timing?!?!?!?!?!
Hey all, I need help!
I'm firing up my new ramjet350, and I can't find any "traditional" timing marks on the balancer... There is one line cut in it, with one little white dot, which I assume is TDC. Anybody been in my shoes that can help me figure out where the heck 10 degrees TDC would be? I actually sanded the paint off of the balancer thinking that the paint might have covered the stampings, but... NOT.. They aren't there. The instructions tell me to set base timing at 10 degrees BTDC, but I'll be french dipped if ith balancer is marked! You'd think for a $5,000 crate engine, they'd give me timing marks! Please help, I'm completely frustrated! Thanks in advance.
Avatar is a pic of "Before"... Just wait.. ---------------- 1969 Fleetside: Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans. 20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit). Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all ---------------- Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!! ![]() |
Re: NEED HELP Ramjet 350 base timing?!?!?!?!?!
Where is your timing tab on the motor?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
The timing tab is on the timing cover... Not very traditional, firstly, it's PLASTIC.. There's a little "V" in the cover with a white dot, and on the balancer, there's a groove cut into it from the front (toward the radiator) to the back (toward the block).. I am assuming that it is TDC, and am looking for the degree stampings, but there anre none.
Thank you for your speedy reply. ~Russ
Lke this:
#5 | |
![]() Join Date: Jan 2008
I installed a Ramjet 350 in my son-n-law's 87 chevy and ran into the same problem. I asked all over the place and could never get an answer. I tried measuring the distance from TDC to 10 degrees on a old 350 I had and setting the Ramjet approximately the same distance from the V notch (assuming it was TDC). The motor seemed to run best with the balancer mark lined up with the V notch, so thats where I left it.
If you ever find anyone that knows for sure where it should be set, let me know so I can make sure his is correct. |
#7 | |
Clearly, I found the same lack of information on the web as you did, and the manual is less than clear! When I get it figured out, I will let you know! Thanks for the reply.
Have you ever seen one of these engines?
#9 | |
New Member
IF I ain't mistaken,which that would be something new,is the timin is set at the 0 degree mark at the factory and the computer also handles all the advance and the injectors timin and also the ratio on the fuel and air.If it works like I guessin like,if you would try and advance the timin,the computer would try and reset the timin and make it worse than when you started.Of course I could totally wrong,too!!
#11 | |
Chasin' the Dream
Gilbert Chevrolet lists them as on their RAM JET 350 SERVICE PARTS LIST as 12562818 Plastic Timing Cover with Timing Tab This can be found on their site link I not sure about comp controlled timing, but I think you still have to set initial timing at what did you say 10* BTDC? Hope I'm not way out in left field and this is what you looking for!
Born with a Bowtie ![]() 1971 C/10 350/350 Daily Driver/project Assumption=The mother of all ![]() |
Not Ram-Jet-just the regular one's (metal cover). These come with the timing tab.
#14 | |
![]() If I need to change the timing cover, I'm in for some work... I already have the March drive system installed, engine is in, radiator and fans are in.... Coolant level is topped off... Well, at least it looks pretty! Thanks for the replys from all, I appreciate your help!
#15 |
![]() Join Date: Dec 2006
What would happen if you used an adjustable timing light and just set it at 10 Degrees with both marks lined up? Just a thought,I don't know the answer.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#16 | |
I guess with all the other goodies and cool tools I've bought for this project, I should stop whining and just go get one... ![]() Frankly, that's the simplest answer!
#17 |
Not sure I completely understand the problem. It's easy enough to find TDC with a piston stop - start there. Once a TDC reference is established, put some timing tape on the balancer and you're done.
If I'm missing something, let me know - but this seems like a quick and easy fix... |
#18 | |
I used my piston stop tool and verified that the lone "V" on the timing cover tab when lined up with the line on the balancer is indeed exactly TDC. I put timing tape on the balancer and am good to go. Now I can set the timing to 10 deg BTDC with a timing light. |
#19 |
I was thinking this engine was plug and play... i didnt realize you had to set up the balancer or anything...
1986 GMC K15 4.3V6/SM465/NP205 will be converting to 5.3LS E-ROD/AA adapter/SM465/NP205 10 Bolt Axle Rebuild Tutorial: http://67-72chevytrucks.com/vboard/s...d.php?t=536415 |
#20 |
As you can tell im pretty new at doing engine swaps
